- Feb 17, 2013
OK, I picked this up off the bay. It was advertised as a "Camillus Becker knife blade blank" and the description read
"Blade blank is tanto shape and supposedly D2 steel already heat treated with a thickness of .252 on the blade down to .247 on the handle. ".
It kinda looked like a Becker, but 1) the blade has a tanto tip, which, I understand, Ethan doesn't like. I have never, in my short experiences with Beckers, heard of a D2 version. I figured what the heck and bid on it.
The thickness seems to kinda match the Camillus Becker specs (allowing for future finishing to thin it a little).
According to communications from the seller, he bought it "years ago" as a kit (came with a couple of black canvas micarta handles drilled to fit the holes. No hex head holes. Just round ones on both handles.
Well, it here.....
IF it's a Camillus Becker, it's nearly the same size as a Cam BK-2
But, it has a thumb ramp and a finger guard reminiscent of a Camillus BK7
But wait.... it has a skeletonized handle, like the Kabar BK2 (I have never taken the handles off one of my Camilli Beckers. They are glued on.) I was under the impression that the Camilli Beckers were solid handles. ????
Here's the blade portion in a close up view.... Note the thumb ramp has FIVE grooves, not THREE like the BK7 and BK9
Note that the blade appears heated - BUT is is yellowish along the edge and bluish in the middle. If it was truly heat treated, I would think that the color would be more uniformly colored. Having never performed a heat treatment process myself, I don't know.
The edges APPEAR to be laser cut, not water-jetted. I think it is not heat treated, just laser heated. The previous owner looked at the discoloration and assumed that when he was told it was heat treated D2, he took the seller's word for gospel.
And here's the handle by itself... The screw holes are larger than and the distance between the two end holes is about 3/8" LESS THAN the distance between the same holes on a Kabar BK2. Therefore, standard handles do not fit.
My observations lead me to conclude the following:
1) It is definitely NOT a production Becker of any sort.
2) It is not heat treated.
So the question that remain are:
Is this
1) some sort of prototype or maybe a "dorking around the cutter" blank from Camillus?
or
2) a wanna-be Becker look-a-like?
or
3) a blank for some other model of blade made by Camillus or someone else
Also, is there someway to test for what the type of steel is so I can have it heat treated the proper way after I get done finishing it?
Now here I sit, waiting to be enlightened, hoorahed, slammed, etc.
Well, it here.....
Is this
or
or
