Camillus Blaze robo-problem
I just got a Camillus Robo Blaze and I like everything about the knife except that the Robo Power assisted open mechanism is not assisting. It does not appear to be functioning at all. As there is no such thing as the Camillus warranty dept. any longer I am considering taking it apart to see if I can see what the problem is. Before I do so I thought that I would see if any one has done this before. Is there any reason to be concerned about it not going back together correctly?
Thanks for any help.
have your tried taking it apart and cleaning/lubing? do you feel any resistance while closing? i assume the blade is not springing open to the locked position
I have not disassembled it as I was unsure whether I may damage the mechanism. There is no spring what-so-ever & no resistance when closing. The knife does open/close smoothly.
sounds like the robo spring is broken if there is no resistance when closing and that it opening and closing smoothly
I have taken both my robos apart for tuning, polishing, and general nosiness. If the robo spring broke, something crazy happened, as it is a long, leaf type spring, that spreads the torque across a rather long arc, not very prone to breakage, although stuff happens of course.
1. have proper fitting drivers.
2. take clip off so everything lays flat
3. lay the knife with the right hand side (if holding the knife in hand edge down) on the table/bench
4. carefully remove the back screws and push/tap out the opposite side
5. remove the stop screw, and push/tap out the opposite side
6. remove the pivot screw, and " " "
7. now very carefully, and slowly remove the left side of the handle
8. make sure to make note of the washer config. as it must be repeated properly for good function.
9. the spring should be staring at you, lying in the right handle, and there should be a small nub/pivot point on the blade that the spring works on.
10. clean everything, apply a light coat of quality lube to everything that touches anything that moves, I use Tetra, but whatever suits you.
11. re-assemble and before really tightening it all down check for function. If it all works right, then snug all the back end down good, and slowly and carefully snug the stop & pivot screws to allow proper tension, eliminate blade play, and center blade when closed.
I was moving quick, and might have left out some junk, so I guess this is my feeble attempt at a disclaimer. Good luck!!!:)
beckerhead gave a great description of taking down and putting back the knife. On mine, when the pivot is overtightened, it opens and closes like there's no spring. Try easing the pivot in about 1/8 of a turn increments and see if that helps. I usually save that for last after cleaning. (guess you HAVE to do it last....) I use a drop of loc-tite to keep the pivot in place. Its a fine line between no blade play and smooth opening action. Play with it a bit and you'll figure it out. Hope that helps
Marc
