"Why do you review knives that are discontinued? The Buck Odyssey, the Schrade Switch-It, and now the Camillus CUDA EDC? What's up?" Well, while it's true that these knives aren't being made any more, but they're still readily available and still very good.
I found this knife at the local knife shop for $40. It's US-made, and has a blade steel of 154CM. It's a great size for EDC (hence the name) and has just about everything you could ask for in a quality blade. The entire knife is 3 ounces in weight. And now, the details...
Handle Details: The CUDA is 3-7/8" closed and 5/26" thick, not counting the pocket clip. The handles are skeletonized, and made of 420HC stainless steel. There's a nicely-positioned groove for your palm, and the spine has thumb ridges near the blade pivot. A lanyard slot is provided. The entire knife is held together by three Torx bits - two T-6 on each side (one is holding the blade stop) and one T-8 on the left side to hold the blade pivot pin. there are NO sharp spots on the handle at all. It's actually one of the most comfortable knives I've held. The back of the handle is open so you can blow out debris, and it locks very positively with a frame lock. The lock engages the blade for over half its (the blade's) length, and there is no blade play in either the open or closed position.
The pocket clip is mounted for right-hand tip-down carry, and it's held in position with three Torx (T-6) screws. It also has the same skeletonixing as the handle. The pocket clip engages a full 2" of your pocket, and exposes only 1/2" of the handle when clipped inside a pocket.
Blade Details: The CUDA has a blade made of 154CM, and it's 3-1/8" long. It has a flat-ground blade (not hollow ground as I previously thought) that came relatively dull. It was made shaving sharp with a little patience and a few cuss words. Truth betold, it only took about 10 minutes, but it seemed longer. The blade has dual thumb studs, and the studs can be removed with a Torx (T-6) bit through the right side. The left side of the blade has "CUDA USA" above "EVERY DAY CARRY" above "D RALPH DESIGN" all lasered on. The entire right side of the blade is blank. The blade has a recurve to it, and an effective point should you want to pierce with it. Inside, each side of the blade has a white nylon bushing. The blade opens smoothly, but it takes a bit of effort to get the blade out of the detent. Once it gets going, it's smooth. This is a nice blade shape and length, and is very nice for an EDC knife.
If you can find the CUDA EDC (there were some Taiwan-made ones with AUS-8 steel) pick one up. You won't be disappointed.
PHOTOS ADDED:
Top view, showing the open back...
Showing the liner lock...
PHOTOS ADDED:
