Klesk
- Jan 5, 2003
I just opened up the box of my Dominator, and I wanted to share with you some of my initial impressions.
General
The shape and texture of the handle is pleasing to the eye as well as to the hand. It is very comfortable, and grooved in the right places. The size of the knife is about what I expected - approximately the size of my MT LCC, though a little thinner (and lighter). The blade on my knife is centered, and there are no major flaws.
Fit and Finish
Upon closer inspection, the frame cutout has a small area that has been left "rough". There are a couple of tiny, jagged titanium spurs sticking up - luckily, there is no way to catch a finger or clothing on the spurs, so they do not affect the knife's function. It is just a cosmetic issue, but bothersome nonetheless. The blade has a nice stonewashed-type finish, though not quite as nice as Microtech's. My knife has a bunch of dark lines on one side of the blade. They look like scratches or tool marks that were not polished out; again, only cosmetic, but still bothersome. The blade edge grinds are clean and even and the knife is rough shaving sharp. That is, it will shave with a little bit of effort, but is not hair-popping sharp. It will take a little work to get it to "scary sharp" the way I like my knives.
Robo-Assist
Of course, the first thing I did when I opened the box was to try the Robo-Assist feature. I was initially disappointed, in that the blade took a hefty push to get moving, and then the blade would only open halfway. I opened the knife and thumbed back the framelock, and found that the blade didn't move very easily. Once I backed-off the pivot pin to the point that the blade moved freely when the framelock exerted no pressure on it, the Robo-Assist worked quite well. The blade moved out smartly, though not as quickly as a Kershaw Leek. Of course, this is to be expected since the Dominator's blade is much heavier than the Leek's. Likewise, the Leek's blade does not move as quickly as the lighter Chive's. One thing to note about the Dominator's pivot tension adjustment: there is a stop pin right next to the pivot pin that is held in (like all the other frame pins) by a Torx screw. Because of that pin's proximity to the pivot, it is difficult to judge how far the pivot can safely be backed off. At one point, I had the pivot so loose that it was exiting the frame, yet the blade did not wiggle because the stop pin was holding the frame together. I'll probably loosen the pivot until the blade just starts to move freely, then Locktite it in place there.
Other Notes
My particular knife has been heavily lubricated, both on the pivot and on the torsion bar that makes up the Robo-Assist. If I put it into my pocket like this, the lubricant would soon be full of pocket lint - I'm sure this would impair the functioning of the Robo-Assist.
Closing the blade feels very unusual. There is the initial resistance when encountering the torsion bar, a very definite point at which the bar hits center, and then the final closing with little tension and the engagement of the blade's closing detent. I'm not sure if the torsion bar holds the blade closed also, but the blade is difficult to open when just grabbing the exposed top and pulling. I don't think a "normal" knife is that hard to open, when only the blade detent has to be overcome.
Finally...
I like this knife, it will be a keeper. It's a good-looking knife, and of a useful size. It doesn't hurt that the blade is S30V, a steel with which I have had positive experience. I am going to take apart the knife tonight, clean up the extra lube and remove the torsion bar (it looks to be held in by one frame pin) and see how it functions as just a plain old framelock and if the torsion bar is actually exerting some closing force on the blade. The Robo-Assist is cool, but it may attract too much attention. If anyone is interested, I'll let you know how the knife functions without the assist.
General
Fit and Finish
Robo-Assist
Other Notes
Finally...
