Hi everyone. I just received these two knives recently and was surprised how similar they were. On doing a search, I found that the issue has come up before. However, I already took the pics so you might want to look at them anyway.
The pictures highlight the design similarities of the two knives. I personally find the EDC to have the edge in the looks department, partly because of the shape of the pocket clip, though the Vapor has a really nice cut out for the lock release. The Vapor seems to have slightly thicker handles, which means the integral lock would be stronger. Then again the lock up on both is very secure.
Bad points? The thumb stud on the Vapor, as has been pointed out before, is POINTY!, it definitely needs to be sanded or filed down. I found the "saber grind" on the EDC to be a bit... wimpy? It would benefit from a more precise and dramatic grind.
I got the Vapor from Bayou Lafourche for $21, a 3 1/2" blade version is available for $24. The EDC came from Knife Outlet for $50. I can recommend either as an inexpensive "edc", and for those of you who find the EDC to be just a bit short, the 3 1/2" Vapor might be an acceptable substitute.
John.
John.
