camillus edc question
I just got my edc cm154, great knife from my limited experience. My only complaint/question, there appears to be an awful lot of front/back blade play when the knife is closed. You can actually here it rattle if you shake it. It opens smoothly and locks up tight. Should I be concerned,and is this normal. Thanks for your help, newknifeguy
newknifeguy,
I'd like to help you with your knife. I'm not sure which 'way' your blade has play in it, but it is usually best explained of\ver the phone. If you would email me your phone #[day or nite], I'll call you asap on my nickle. I look forward to talking to you.
Stay Sharp!
Will Fennell
Camillus Cutlery
www.camillusknives.com
Where else do you get service like this?
BTW Will, mine is as solid as a rock.
"Will work 4 Knives!"
My PhotoPoint Site
Based on my own EDC, I would guess that you are noticing the play between the blade hole and the pivot pin. There is a noticeable amount in mine too. Just tighten up the pivot tension scew a little bit, and it will no longer rattle.
Steve,
I think you are right, just a loose pivot, but I want to make sure. It's alot easier get somebody on the phone and talk them through it. I just answered a similar question for somebody else on the telephone. I don't know if most folks understand the importance of keeping your pivot screw "relativly" tight in a frame lock [or liner lock]. This ensures that the lock arm and the blade contact at the the same angle everytime, which is of course important for consistant lock-up. This is what regulates the dreaded "blade wobble" that everybody looks for. Also, a loose pivot is usually the culprit when a blade doesn't "fall down the middle" when the blade closes. If the pivot is loose, it allows the lock arm to puch the blade off center slightly, which of course shows up out at the tip of the blade much more readily.
I said that you should keep a "relativly" tight pivot, because of course, a screw type pivot is user adjustable. You can tune the action to your liking. Alot of folks loosen their pivot up so the blade opens VERY easily, which can make for alot of fun, flicking the blade open. As outlined above, this can cause other problems, plus it will usually speed up the wear and tear on the knife's lock work.
Sorry Steve, I know you know this stuff, but it just kinda rolled out
If folks have any more questions about CAMILLUS/CUDA/BK&T/WESTERN knives, feel free to come on over to the CAMILLUS forum here on bladeforums, and we'll do our best to help.
Stay Sharp!
Will Fennell
Camillus Cutlery
IMHO every knife owner should also have a rather complete set of Torx drivers/Allen wrenches in the smaller sizes.
Most knives, no matter how high the quality, eventually will result in a loose screw at the pivot or elsewhere. It comes with the territory.
