- Jan 31, 2011
just ordered my self a spyderco sharpmaker, i don't know any thing about sharpening.... any advise?
I didn't coin this phrase but find it's spot on, it should be called the "SharpKEEPER" not "SharpMAKER". Having said that, I like it, A LOT! Have 3 of them stashed around in different palces.
They work great at maintaining an edge or micro bevel that is already at or slightly less than the Sharpmakers preset angles, i.e. 30 or 40 degrees. Changing bevel angles, especially large changes, can be frustratingly slow with the stock "sticks". Search the archives for inexpensive alternatives for XXC, XC stones that will speed up the bevel changing process. Once you have the bevels on your knives within the 26-30 or 36-40 degree range you'll be able to keep your blade razor sharp with little effort using the sharpmaker.
Again, Search this forum for "sharpmaker" and you'll find a months worth of reading.
yep, I pull out my sharpmaker to dull my knifes if I feel like I need pratice sharpening my knifes as well. sorta hard to put a hair popping edge on an already sharp knife!
those sharpeners are expesnive but there are other options which are just as cheap adn work much faster.
any advise?
How often do I really need a pocket knife you could do eye surgery with?![]()
