I have been using one of hugh mcdonalds early proto types. I helped make it with Jim STEELE, it works very well.
The mill is at my house for a couple of weeks while Jim is shifting house. (lucky me)Jim told me to use it, he did not have to say that twice.
THe only problem I had was operator error and poor set up. It was not near my anvil and it was raining outside my little shed.
The limitation I found was the bottom movable roller needs a bit more clearance front and back. It is hard to describe so send me an email address and I'll send what photos I have and a better description.(this offer open for any one)
Basically if you are inexperienced the metal can start to bend downwards as it rolls out toward you. In front of the roller there is a bracket for strength. Twice the bottom of the billet caught on the leading edge and ripped the welds open.
There is a tip, you want the mill to push the metal back toward you, not pull you in if you get anything caught. Fingers at 2.5 in per second.
I spoke to jim about the problem he assured me it is a bit of practice and possibly rolling when to cold.
I made 6 billets during the day I have done that with a ten pound hammer. The mill is great.
Something else to consider is a spare roller. The 2 parrallel rollers squirt the metal out length ways but not much side growth in width.
If you had a second roller with a convex curve it may be able to get some width. Depends how much time you wanted to spend bolting up.
Im sure someone else will say it start with wider stock.
I'll wait to get a message And Ill send some pics.
My email address has an under score not a space if you have problems.
reg_ellery@optusnet.com.au
