Can Busses really take 20,000 pounds before breaking?
jeepin
Just curious if they really can take that much weight before breaking, so I figure they ought to beable to take a lot to just bend them as well?, anyway, I stuck my new to me Natural Outlaw in our downstairs doorway between a 2 2/4s and just pulled, with not that much pressure, and it looked like it was starting to bend.:( , or was I seeing things?. Makes me nervous, is mine bad or was it just my mind playing tricks on me?..
sure it will bend, but it should spring back straight again.
remember kids not to try this at home, the knife could blow up and cut your jimmy right off at the roots:eek: :eek:
If I remember the test right they should bend to a 30/40 degree angle and still return to true.... i believe the breaking point was beyond a 90 degree
Originally posted by jeepin:
it looked like it was starting to bend. or was I seeing things?. Makes me nervous, is mine bad or was it just my mind playing tricks on me?
Uh.....yeah...yeah...that's it.....it's a bad one......real bad....probably gonna blow up in a second here. Better put that NO in the mail to me so's I can put it in the DISCO (Damaged INFI Storage Container Object) by my bed. That way it won't hurt you when it goes off. ;) :D :rolleyes:
No, no.....Don't thank me.....That's okay....I'm just a giver....anything to protect a fellow INFIholic from a most unpleasant consequence. You can send it to me care of the head warden at Oopsie-Daisy State Penitentiary, 1 Wanna-Quitcher-Bitchin Kangaroo Court, Hasseled-Bad, Portuguese Samoa, OICU812. Just mark it "Birthday Cake." ;)
Seriously, my guess would be that the wood in the 2x4 supporting the NO probably crushed a bit under the weight. Most 2x4 are made of soft pine and it doesn't take much pressure to deform it. While the NO may have flexed a bit under your body weight, the likelihood of it breaking is extremely small, especially at the blade-tang junction. There are pictures around of a Busse INFI blade taking a 90-degree bend without breaking. Before it took that bending, it was flexed about 35 degrees and returned to true (straightened out). Part of the beauty of INFI is that the metal matrix holding the carbides is incredibly tough and extremely difficult to tear. It is, however, a bit ductile. That is why Busse edges can survive harsh edge impacts without gross failure -- the edge deforms & rolls, but will chip out only with extraordinarily severe forces applied.
Regarding that 20,000 pound blade-tang junction failure rating: I figure if I'm ever in a situation that requires the knife in my hand to use the difference between a 12,000 and 20,000 pound junction strength, I will have much bigger worries than whether my blade is going to hold up.....Like where to find the molecules of what used to be my body. :(
If you have any doubts about your NO being able to perform up to your standards, IMHO go out and beat the snot out of it in an empirical test. See if it can survive whatever constitutes a severe knife test in your opinion. Beat it, chop with it, hang your body weight from it, poke sheet metal, make sandwiches & leave mustard on the metal, do whatever you like to it (no cutting torch allowed ;) ). Even if you do manage to break it, Busse will replace it. BTW, I'm betting the NO will pass the test with flying colors. :) Let us know how it goes.
For further reassurance, read the comments about Busse knife testing linked from the thread below, including a test by Mike Turber of a CS Trailmaster and a Busse Basic 9.
http://www.bladeforums.com/forums/showthread.php?s=&threadid=203645
Somebody posted something like this once :
If you are in a situation where your Busse blade has been broken.........then you are dead too !!!
:( :( ;) :) :D :D :D
JRL
Jeepin,
No worries my friend!
Pork Jok,
Your giving spirit nearly brought a tear to my eyes!!! :eek: ;)
JRL,
Here's the history behind that oft quoted line:
Once, when a customer at a knife show asked, "What happens if I break my Busse knife?" my dear friend Jerry Snyder replied, "You have no worries my friend. . . .'cause whatever broke your Busse knife, killed you 5 minutes earlier!" ;)
Can it really take 20,000.................Well I have stood on one!!!!:D
So what you're saying the 20,000 is being way conservative for safety but in reality a Busse can much more? :D
Thats right maybe a shot show we can really put one to the test & have Jerry & I stand on one:D :eek: :D
Infi is tough,I have hung from my SJ to see if it would fail and it did not although it did bend,but it should bend.Any good steel will bend before it breaks,however I do not believe it can take over 10 tons of pressure before it will break.Thats more than some ton trucks can haul.Alot yes,but 20,000lbs?Cmon surely not?
steelheart e, 235lbs of pure pork sausage flexing it. only killed 12 campers when she gave way:cool: :cool:
Jerry's pounded way more beers than that, and he's still in his prime. I wouldn't worry about it. :D
That 20,000lb quote is at the handle, not anywhere near the tip. The bending of INFI when you pry with it is completely normal, and engineered. It is designed that way so that it WON'T snap or chip. Try breaking your Busse by prying, it won't happen under normal human strength without leverage. As far as I know only one Busse has ever broken from prying. It was modified INFI, and the heat treat had been comprimised by an after market modification.
Maybe your Busse's not the same thickness as the one with the 20K lb. tang failure rating.
