Hello, my CF Sebenza has a few marks on the carbon fiber side. Was wondering if it was possible to have these repaired by Chris Reeve when sending in for spa treatment?
I have refinished carbon fiber plenty often. Sand paper and some buffing. Or just a high grit. Done. I suppose it can depend on the material but I have done it with carbon fiber as well as g10\carbon laminates.
If they won't and u cant. I will. But I'm sure you can do it.
Unless your marks are deep I doubt you'll "Buff" down enough to see a major grain pattern difference.
I'd just buff it with as high a grit paper you can find (wet is best CF dust is yucky)
Stick it to a piece of granite or glass or what ever you got that's flat (dead flat is best)
Then lay the slab on it so it lays flat give her a few strokes see if the mark comes off. Then you can buff it by stretching a T shirt out over your flat surface and hit it with some mothers polish
That's what I'd do if I was concerned about it .
my opinion not carved in stone
If u go deep it will alter the pattern. But it usually keeps an even look. Just do as he said. Lay the paper on a flat hard surface . gently sending as the fellow above said.
Good luck
