Can I Change the Lugs on my Sebenzas Myself?
Lone_Wolfe
Mrs G.
Platinum Member
Hi all, I've got a few Sebbies and I want to change them around a bit. How would I go about removing and replacing the lugs on the bladse?
The studs are press fitted, the single stud is easy to press out the double lugs are not. If you are only changing Sebenza thumb studs about I wouldn't bother. If you want to put on a different style of thumb stud then there is more point to it IMO.
I want to switch out the single lug on one blade for the double lug on the other.
That will be a nightmare, you will be far better off sending it to CRK for that to be done.
Just to further complicate the DIY picture, a small dimensional problem can result in a cracked blade. I'd send it to CRK...
