Thank you for the reply. What would you recommend for smoothing the micarta after filing/sanding down the pin? I have 220 - 2000 grit sand paper and simichrome polish.Yes, you can, provided the peened brass isn't the only mechanical connection between the scales and the tang. Depending on what equipment you've got, you can lay tape over it, poke a hole so the brass you want to reduce pokes through, and file it, or sand it down, in which case you'll probably mark up the micarta and have to smooth it out afterwards.
I don’t see anything either.Am I the only one who doesn't see any pics?
Two impressively long strings.Instead of pics, I see random characters. Might want to check the bb code.
