is the steel available to buy anywhere other than finished Busse knives? ..
as i know , forged blade more tougher than iron slab ones .
Maybe ask Garth at the custom shop for an Infi blank.
The Busse swords are not forged and they perform just fine.
If you read some of Kevin Cashen's posting here, and articles on his web site, you will see how he explodes the myths and BS surrounding forging.
http://www.cashenblades.com/articles/articles.html
It sounds like it can be done, but it's not easy and the chances of getting your hands on a slab of stock are almost zero.
http://www.tzknives.com/articles/INFI.html
I may not understand things as well as I think I do, but while INFI is a pretty good base steel, isn't the real "magic" in the cryogenic heat treatment? If one was to forge INFI steel, they'd still need to heat treat it (a process that varies significantly from one steel to the next). Heat treat your blade wrong and it'll be far inferior to a correctly treated O1 blade, which many knifemakers use because it's fairly easy to treat.
