I have a Western model 66 with these issues, can it be repaired and how? Thank you for any and all input.
Yes, it can be repaired.
Do you want to attempt it yourself, or have someone else do it?
Thank you Bill for responding. I guess there are several factors that would determine that answer. How difficult is it for someone who has never done that, but has a teachable sense. How expensive would something like this be to have someone do it and time frame? Also, if someone were to repair it other than myself, I would guess they would prefer the unsharpened edge to work around, before I sharpen it.Yes, it can be repaired.
Thank you DMG, not sure how I would tighten the pommel nut as everything at the butt of the knife is flush. Were you able to see the pictures and video?Clamp the blade in a vise vertically. Tap the pommel down with a plastic or brass hammer. Tighten the pommel nut on the end of the tang. You may have to retighten it after use and handling works everything into its place again.
Yes. I’ll look at my similar Western but it looks like someone ground off the end or I am wrong and it is a press fit. Either way, lock in a vise, tap down the pommel and see if the brass is a threaded nut.Thank you DMG, not sure how I would tighten the pommel nut as everything at the butt of the knife is flush. Were you able to see the pictures and video?
Thank you, I'm sure the issue for me will be removing the nut to begin with.On that model, after the round brass nut is threaded onto the tang they ground the entire surface flush (pommel, nut, tang). The nut very likely was originally a lot longer, with a slot across it for a screwdriver. Then that entire end of the nut was ground off after installation.
Depending on the thread pitch of the nut/tang, there are replacement tang nuts available. I see them in 8-32, 10-24, and 1/4-20" thread pitches.
Do you want to attempt it yourself, or have someone else do it.
What kind of money are we talking to have someone fix it. I saw on line where you can buy the replacement leather rings, but I do not believe I will have what it takes to fix it. I believe it is a Camillas single tang with aluminum finger guard.Yes, it can be repaired.
I sent you a message through an email on your contact page. Thank you.I don't really know. I would think it could be repaired within an hour. Maybe even a half hour.
Without having hands-on, that's about all I can say. My labor rate is $90/hour.
