can Mulder hold his breath
Cobalt
Platinum Member
ok, here is another one that I did not post in the original thread, because it is special enough that I wanted to make a special thread for all those SHSH lovers of which I am obviously not one, but this one almost makes me want to keep SHSHII's.
Anyway, this 0.30 nch monster is a smooth handled birds beak SHSHII. but there is a little trick in it: see if you can tell what it is
here let me help you guys guess what the aberration is:
this is the nicest SHSHII I have seen and I am not a fan of them. Too bad this thing isn't another 2 inches longer.:mad:
It has no butt............................. hole, thus not a BBSHSH!
I think it is a SHSHII that has had a birds beak ground into it, you better send it to me to figure out what it is..............
It has no butt............................. hole!
I think it is a SHII that has had a birds beak ground into it, you better send it to me to figure out what it is..............
Ducci,
He'll send it you so you can drill one.
Cobalt apparently found the location of a stealth HOG, infiltrated, and is now displaying the bounty.
It kind of reminds me of the middle knife here............
:D
Now that's one I've never seen before!
Is the edge of the butt still coated? :confused:
And good catch on the center fastener being smooth. :eek:
Definitely some cools old school in this score! :thumbup:
Ducci is correct, it is an SHSHII with a birds beak and a solid bolt in the center and slotted bolts on the sides. A crazy one off. It is also super fat at just over 0.30 inches thick. too bad it isn't 10 inch blade. Can ducci cold roll the blade out to 10 inches?
Send it to me, I'll see what I can do!
You want something like this?
:D
Uh no! Ducci called the hole in the butt, i called the middle fastener! props where they belong. LOL!
very true you did and you called it right on, that is the only difference between slotted bolts and smooth bolts. But Ducci called it right on about it being an SHSHII with a birdsbeak ground on it which makes it rare kinda like his middle except this one has the smooth handle instead of the partially grooved handle.
