i have a Gerber Prodigy that i have been working on to try to get it as sharp as my ESEEs.
- right out of the box w/ my izzy i can shave some arm hair and it looks like i hit it with a razorblade
- out of the box the gerber felt like some one went ripping thru a warehouse full of cardboard boxes when they finished they packed it up and sent it out. i changed the blade angle to about 44* now when i scrape my arm i can see a few hairs but it just lays over most.
Im using a Gatco Professional edge maker 22* on both sides
Stropping with cardboard
could the blades metal have somthing to do with my problem ?
is it just my skills for making it sharp are lacking ?
Is the Gatco garbage ?
All of the above ?
Info from Gerber's website
Gerber Prodigy Survival Combat Knife
Key Features
* Based from the ever-popular Gerber LMF
* MOLLE compatible
* MIRS compliant
Product Description:
Built from a full tang piece of 420HC stainless steel, the Gerber Prodigy model 22-01121 is modeled from the ever-popular LMF knife. MOLLE compatible and MIRS compliant, the Gerber Prodigy has non-dection features like silence when removed from the sheath and non-reflective in light. This knife is a basically a smaller version of the Gerber LMF. The sheath has straps so that you can attach it to your leg.
Technical Specs:
* Overall Length: 9.75 inches
* Blade Length: 4.75 inches
* Blade Material: U.S. 420HC Stainless Steel
All of the above ?
Key Features
* MOLLE compatible
* MIRS compliant
Technical Specs:
