When I said anneal I meant to a completely soft state. I was trying to file the small blades down after forging and the file would not cut the metal. I assumed I could soften the steel by heating non magnetic and placing in a bucket of lime. I know the 10xx steels will do this easily but I didn't account for the fact that tool steels are a different animal.JOnes,
Fill out your profile so we know where you live.
I suspect you are using the terms "Temper and Anneal" in a way that most of us use harden and temper.
Tempering is done after hardening to lower the hardness to a non-brittle and usable point.
Annealing is done to soften metal (before hardening) in order to machine and work on it easier.
Yea when you said temper, I'm thinking 350ish area F based on the chart. That...you can do unevenly in a kitchen ovenWhen I said anneal I meant to a completely soft state. I was trying to file the small blades down after forging and the file would not cut the metal. I assumed I could soften the steel by heating non magnetic and placing in a bucket of lime. I know the 10xx steels will do this easily but I didn't account for the fact that tool steels are a different animal.
Sorry if I was not clear on my terms. I know O-1 can be tempered down to a working hardness for a blade using a kitchen oven but I didn't know if the back spring could be tempered using the kitchen oven.
I mention Keith Johnson of Great River Forge, who I consider one of the best slip joint makers alive today. This is how he still tempers his carbon steel slippies and uses the same sardine can he has used for years with used motor oil.That video shows how fellows like Bill Moran did their springs. Bill had a steel baking pan he set on the coals and put in kerosene. It worked quite well. It does take practice and safety precautions.
