- Oct 18, 2001
In the "looking for a sword" thread I posted a while back, Sarge made a comment about leaving the blade bright and shiny. That got me thinking that maybe because I did only satin finishes on the CD, perhaps folks were concerned that a mirror polish is too "out of reach".
Well, let's hope this thread puts and end to that myth.
If I can do it - anybody can.
Ok, for starters, I forgot to take any "before" pics, so you'll have to put up with a short story first.
I was in the process of negotiating a trade or "loan" with a generous forum member when Uncle stepped in a sent me a Patang. It arrived on Saturday morning. I opened the package and unsheathed it - what a beautiful short sword! Then, much to my delight, I saw that it had a significant bend in the tip ~ around 1/4" long.
That was all I needed to see to know that this usurp everything else and become the #1 project on my list that day. So, I set to work. Here's a list of mods:
1. Straightened the tip at the grinder
2. Reground edge - convex edge now.
3. Refinished blade on sander and buffer to a mirror polish (more on this in a minute)
4. Sanded handle down
5. New "wiping oil" finish (again, more later)
6. Sharpened to a razor edge
7. Coated with Briwax (blade and handle)
Ok, now an explanation for #3.
The reason I ground a new edge was that this one came with a few "waves" that I wanted to get out. Plus swords like convex edges.
So, I started with a 60 grit and worked my way up the entire scale: 120, 180, 220, 320, 400, 600, 800, ending on a felt belt loaded w/ compound. I use this process on every "project" even when I'm doing a satin or handrubbed finish. There are still scratches on the blade at this point and the polish is just a bit cloudy. It's the next step that really makes it shine. A sisal cloth wheel loaded with white compound. I don't have a buffer (don't want one, either). I use the wheel in my variable speed drill press so I can turn the speed down to a safe RPM. Takes about 5 minutes of buffing.
Magic polish restored!
Explanation for #5
I explained most of the process in another thread that ept777 started. Bascially it involves sanding along the grain instead of against it, and then ending at the buffing wheel with white compound.
However, I left off the formula for the finish. First, let me say that I do not like TruOil for knife handles. Instead, I use a combination of Tung Oil, Boiled Linseed Oil and Acetone (2:1:1). Each time I put a coat on, I immediately wipe off the excess. I put on the next coat as soon as the first one dries. At first, this is about every 15-30 minutes. Then it lengthens out to a day or more. When it reaches this point, I stop and let it dry for a couple of days. I then make a decision about whether or not I wanted a hard "final finish" on it. If so, I clean it with a cloth dampened with acetone, then coat it with either a satin or glossy "wipe-on" polyurethane finish (available at Home Depot, etc.). This does wonders for waterproofing the wood and making a solid final finish.
So where's the proof?
Glad you asked...
Explanation for #5
Glad you asked...
