We have WSSI professionally stabilize all our purpleheart. It stabilizes very well and turns purple after sanding.I have obtained a bunch of planks and need to know if I need to have it stabilized before using it.
It should Paul. The color change occurs as the outside of the wood contacts oxygen. The oxidation causes it to darken. Ergo, if its sealed, no oxidation.
11 years later, how is the purpleheart doing? did it turn brown?I've used unstablized purpleheart for handles. It was a hard wood that tended to splinter for me. Be careful drilling holes. Make sure you have a backer when drilling.
I finished it with TruOil. The question in my mind is "will the purple color stay or will it turn brown?" I wonder if stabilized purpleheart retains its color???
- Paul Meske
so its been 11 years since this post. just wondering: is it still purple?I have had a good bit of it stabilized by WSSI & would not use it any other way. The stabilization prevents the UV light from changing it from its lovely purple to dark brown.
Joe
very nice. I was thinking CA finish would be protective.I've got one I made a couple years back with regular purple heart, un-stabilized I mean...
Here it is when new.
Here it is today.
I posted this about 2 years ago on imgur, but I think I made it about 7 or so years ago...
The finish is CA glue rubbed into the surface and polished via a method I found in a post I saw from Bruce Bump a while back.
You tell ‘em Nat!!!!Wood is wood , and it is best material for handles on knives and it has been used for thousand of years . Why you don t leave it to be wood and you make handle to feel like it was made from plastic ? When wood handle gets wet, the grip is even better ......... appearance or functionality ? Polished and sparkling handle or all fingers in place ?
Why not let wood to grow old with you ? Are you the same as you were twenty years ago ?
