If all knives looked the same, what would be the point?
Good penetration plus an index finger behind the 45 degree angle on the blade will out cut any conventional belly knife 2 to 1.
^^Agreed. Tanto's never really appealed to me. I don't do a lot of stabbing or prying, so tip strength is a non issue. Occasionally I'll find the need to stab someone, but so far drop and clip points have worked well.
45 degree angle like in the above pic and yeah, out cut everything![]()
Ah. So like a box cutter. And using a tanto with your finger behind the tip and using the cutting surface that makes up the tip (the 45 degree angle) that way will outcut any other knife in things like skinning, filleting, making fuzz sticks, etc...
