Can you buff scratches out of a zirconium clip?
Does anyone have any experience removing scratches from a zirconium clip-on any zirconium material for that matter? Is there any polishing material or substance that could buff some small scratches out and return the black mirror finish?
Thanks for any thoughts!
It might help if you could explain it better. What is a zirconium clip-on. Do you mean zirconia or Zr02? But zirconia is colorless and not black as you describe. Did you mean titanium?
Can you take it off and polish it on a buffer? Or maybe use a dremel if you can't take it off. I would try white compound on a felt wheel first, but I think I remember reading somewhere that zirconium is very hard, so you might have to use diamond as a polishing media. Just my guess :) good luck!
Diamond compounds will be the only abrasive hard enough to polish such materials.
Pure Zirconium metal is really soft, softer than pure Ti. If you have a clip make of zirc, it may be an alloy or maybe work hardened to make it a bit springy. Either way, anything that you would use to polish or sand any other metal with will be fine. The black part has me confused, Zirc looks a lot like Ti. You may have some kind of coating there.
I'm guessing the clip isn't zirconium but probably stainless steel or titanium. If it's any of those three metals, it couldn't hurt to buff it with a quality metal polish.
