- Oct 24, 2004
The chiruwa has the pins to the tang...can you chop real heavy with non-chiruwa khuks? I'm sure you can, just wanted some reassurance...
ferguson said:Yes.
Oh, one caveat. On the partial tang khuks like the Berk special (dui chirra) and others with no buttcap, Yvsa recommends drilling the tang behind the bolster and epoxy a 1/8" brass pin, just to be certain. The Nepalis have used partial tangs for hundreds of years, so they should still be ok.
Steve has it right. The reason you try out a new khukuri no matter where you purchased it from is to insure that it is sound and will not break under safe and secure conditions.ferguson said:Yes. That's the short answer.
The long answer is, whenever you get a new khuk (or any other knife that you are going to use) go out and chop with it.Steve
munk said:Satori, the way you use Khuks you're in the same company as Hollow, myself, Yvsa, Heber, Raghorn and others.
arty said:It looks like the villager Ganga Ram is about the same length as the regular model, but with a shorter handle and longer blade.
Is the picture an accurate reflection of this?
Are the other villagers likely to come with shorter handles?
I like the proportions, and that is why I ask.
