Can you straighten rattan?
Kev
Is there a way to straighten rattan?
Any info appreciated!
Does this adversely affect the rattan as it is used for the FMA?
Thanks....
~Kev
Thanks....
~Kev
You can, but the trouble is not worth it. If I remember correctly, you soak it in hot water to straighten it.
from,
delfin
I think you can re-heat your stick (assuming it was fire-hardened) and straighten it with your hands. Heat the stick in your oven and be sure to use oven mits.
HTH.
Dave.
i straighten sticks all the time, when i get sticks they are raw, so we fire harden them, at that time you can straighten them, simply get it real hot and i use my shoe to hold it down and bend it in the opposite direction, then re-heat it and do it again, do it slowly so it does'nt break, i roll it on the ground to find out how staright it is. I have straightened out some pretty bad sticks.
