I have this miracle all purpose cloth that has coconut oil in it and used to clean. Just wondering if it could ruin the scales.
I've got the same cloth. The coconut oil is really just there as a solvent for the abrasive; it won't hurt the canvas, but as others have said, the canvas will absorb it to some extent.
If you're set on using it, I've had luck washing oils out of canvas micarta using dish detergent, water, a cotton rag or soft sponge, and a little elbow grease. That tends to be my go to method for cleaning micarta scales anyway.
220 then 320 sandpaper works great to take the shine off , I like the grip of slightly rough micarta. If you don't like the surface go to 400, 600, 1000, and 1500 grits and you're back to shiny
Regards
Robin
The 1000 grit wouldn't remove the color of the Micarta?
I'm new to the Micarta and curious about how it or if it changes or loses color as you wash it. I just took a sponge with some warm water and dish detergent to the GEC 71 and it looks like it's lighter now. Is this normal with the cleaning and drying process for Micarta?
The canvas is porous, so not entirely water resistant. The canvas fiber and and will shrink and expand with humidity and dry weather, as well as soak up oil and other fluids if exposed for any length of time. In short, don't be overly concerned with it, as stated enjoy your knife and let it age as it was intended to.Is Canvas Micarta waterproof?
The agitation of the surface with sandpaper would slough off materials that may appear white, but it is the color the canvas and the epoxy is very fine amounts, similar to powder. Think about when you sand a piece of wood, you basically get the same results.
Luckily there is quit a lot of information online available to read and learn from. When it gets "washed" it will lose some amount of color and turn a lighter shade of whatever it's original hue was. Because it is losing any surface treatment that was originally applied thanks to the detergent. There is no real cleaning and drying process that I am aware of for Micarta. It's usually been considered a very low maintenance material, unlike Ivory, Horn, or other natural material. Most folks just tend to let it age as it ages. A word of caution, I would not take to washing a pocket knife with O-1 tool steel as the blade as you may end up with significant rust in areas where you may not be able to reach and clean.
Thanks for the information. I'm just becoming neurotic thinking I lightened the color of the Micarta with the Miracle Cloth I used. It looked like there was a little compound left from the factory, and I decided to try the Miracle Cloth to try and get it out. Wipe on and wipe off with a separate cloth.
