Canadian Bushwhacker gets a handle.
Some of you may recall that a couple months ago I spent a weekend at Dan Farr’s place forging out a bowie and hunter blade.
You can read about it all here:
http://www.bladeforums.com/forums/showthread.php?t=411097
Well, this past weekend I had the opportunity to return and learn a thing or two about handles.
The following is VERY photo-intensive, so if you are on dial-up, please see the pics here.
http://www.fototime.com/inv/A796BF162AE4D0E
And if you don’t like in-progress type threads, flee while you still can.
First step was to decide on what type of handle I would go with for the bowie. The primary choices were between a more traditional and conservative design, and something that would place ergonomics and function first.
Dan’s handle design for his competition cutter is about the best I have ever come across for a hard working big knife. Superb control and comfort. I decided to go with a modified version of that design – a bit thinner, more elongated and with a touch less drop (all to better suit the different blade shape of my knife versus his chopper).
Next step was to pick out a handle material. As it happens, Dan had a pretty good supply of my absolute favorite wood – black walnut – so I went with that:
Here we see all the different pieces of the handle layed out. When you see the final product, recall that this handle is comprised of no less than 14 separate parts (the three pins and lanyard tube are not pictured).
Shaping out the slot for the tang to slide into that solid block of walnut:
Then after each piece is cleaned, sanded, slathered with adhesive and stacked onto the tang, it is all clamped together:
While that contraption was left to dry, we moved onto the hunter handle. Same basic process. Here is the blade with the final handle design:
Dan wanted to show me how to do a mortise fit, so we went with a two piece approach on this one. Black walnut was selected again, but from a different block – this one showing some unusual (in my experience, anyway) red tones:
…..end Part 1 of 3
You won’t see a pin in the handle when all is done, but it’s there:
That whole bit was similarly prepped and clamped, and after a time, I started in on the bowie handle which looked a little something like this:
Not an attractive beginning, but some time at the grinder got the basic outline done:
And some more fast-spinning belts shaped it even further, then it was time for some hand-sanding (and lots of it):
Which takes us to this point:
Oops - musn’t forget to drill the holes for the pins and lanyard:
And some more rub-rub-rubbing was in order.
We’ll fast-forward through the hunter. Here is the handle rough-shaped:
And here is the final product (you can really see the red tones in this shot):
… end, Part 2 of 3
Without going into chapter and verse of the design aspects, here is my knife along with a couple Farrs and a Crowell. I borrowed liberally from the design features of each:
Ther was just time to try to whip up a quick sheath for the hunter:
Hand-stitching fun:
And some pics of the final product:
Once again I have to say a huge thank you to Dan for his time, patience and hospitality. One more trip is still in order to do the final finishing on both handles, but they are good to use as is. And man, do they feel good. There is nothing like custom fitting a handle to your own hand – and amazing how a little more radius here and a little less swell there have a huge impact on feel.
Dan was kind enough to put a super-keen edge on the bowie for me – now I just have to go find something to chop.
The little hunter / utility cuts like a laser and will likely see use first as most of my knife-chores are small-knife chores.
Thanks for reading gents.
Roger
ABSOLUTELY A M A Z I N G:thumbup: !!!. Thank you for sharing those wonderful pictures. Theres is no doubt that Dan knows his craft! Could you provide us with some more information such as blade steel, as well as, blade length, width and thickness for both knives?
And we lose another collector to the world of knifemakeing........no seriously though roger awesome job and thank you for the pictures of the process.
Boy am I sitting here jealous and filled with envy. :eek: As I should be.
Roger, there is no one better with the short usage of words. Excellent wrap-up.
Attaboy guys!!!!
Coop
Outstanding.
Roger, you've obviously got a good eye and good hands. Coupled with Dan's exceptional teaching and guidance you were able to make two finished knives that are nothing short of professional-grade custom work.
Thanks, as always, for sharing the journey with us here in the forum.
Thanks for the comments guys - much appreciated. This was a very enjoyable and rewarding enperience, and I am most grateful to Dan.
To try to answer a few of the questions asked,
1) Dimensions are as follows: hunter: 4 5/8" blade, 9 3/4" OAL and approx 3 /16" thick. The bowie blade is a shade under 10", 15 1/4 OAL and just under 1/4" thick.
2) I'm not sure what was used to coat the handles - Dan mentioned but I don't recall the name. It is like a clear coat. The plan is to apply and sand down several times, allowing any open pores in the wood to be sealed, then apply a final coat. There was only time to apply the first coat, but the wood is still well-protected as is. It'll just look a lot better once the final finishing is done.
3) Not sure whether the walnut is stabilized or not - I just know that I am in love with both pieces. You should see the light refract inside the handle of the bowie - it is something else.
A special thanks to my two shop buddies who made the weekend extra enjoyable:
Roger
Pretty easy to teach Roger anything. He has an eye for knives, and a good touch on the machines. Patience for the hand detailing, and he just loves knives. Pleasure to have in the shop. Oh yea, the dogs like him better than me!
Roger, does the knife fit in the sheath? Get some sno-seal to waterproof it, or we can do it on your next visit.
Dan
I would buy either :) or both. :D
Excellent write-up Roger. :thumbup:
Man,those handles turned out as nice as the blades.
I love Walnut,too.
Congrats,Roger! :cool:
Doug
Both of those are beautiful. Excellent tutorial also :thumbup:
Being a lover of more exotic woods , that Black Walnut is breathtaking , I'm sure even moreso in person.
I have a question though and I mean no offense but on the Bowie there is some scale or pitting , was that left on for a purpose ? maybe to add morecharacter to the knife ? Just curious.
Thanks again ! :)
Thanks again ! :)
No offense taken at all. Those marks are a remnant of the forging process where I got some too deep hits with the power hammer. Grinding them out would leave the blade too thin, so I just left them there. I euphemistically call it my "Algonquin Grade Finish". :o I've actually grown quite fond of those marks - just wish I had them on both sides.
Dan - the sheath fits perfectly.
Roger
