mckrob
- Jan 15, 2007
Tired of paying $11.45 a sheet for your 1:50000 topo maps?
There is a relatively new Government of Canada website called GeoGratis that gives you access to the entire National Topographic System (NTS), and best of all it's free!
http://geogratis.gc.ca/geogratis/search?lang=en
Follow my directions below to download any 1:50000 NTS topo sheets you need
1) first you will need a viewer. The best by far is Globalmapper, but this costs money. The USGS has a free "lite" version of Globalmapper called dlgv32, you can download it free from here:
http://tahoe.usgs.gov/viewers.html
http://www.bluemarblegeo.com/products/global-mapper-dlvg32.php
2) to find out what NTS sheet you are looking for, find your local index map here (bookmark this page):
http://www.nrcan.gc.ca/earth-sciences/geography/topographic-information/maps/9765
write down the full NTS sheet numbers that you are interested in (i.e. St John's, Newfoundland is NTS 001N10)
For those not familiar with the NTS system, the first number represents the NTS zone, each zone is 8 degrees of longitude in width, starting at one in Newfoundland, increasing to the west and to the north. Each zone comprises 16 smaller zones represented by letters, starting in the SE corner of the zone, then each of these is broken down into 16 smaller 1:50000 numbered sheets (see the sample index map below).
3) now you can download the individual map sheets from the GeoGratis server (bookmark this page):
http://ftp2.cits.rncan.gc.ca/pub/canmatrix/50k_300dpi/
The map sheets are organised by NTS sheet number (see example above). Map sheets are quite large so they are compressed as zip files, if you don't have it already, you will need Winzip or WinRar to unpack them.
Unpack the contents of the zip file, I would suggest creating a map folder and organise by map sheet number the same way as it is organised on the GeoGratis server. The large "TIF" file is the georeferenced map image.
4) View / print your maps by opening them in Globalmapper (dlgv32). I believe that the lite version will let you open four sheets at a time, this is usually more than enough.
And that is all there is to it! ENJOY !
