Pretty much all my blade making observation has been Forged In Fire. Many of the challenges require canisters and about 90% of the competitors have difficulty getting the canister off. I see most of competitors use whiteout, most not letting it dry before loading it up (makes you wonder if these guys watch the show at all, this is mentioned often). I'm curious if doing something radical like this would work better than whiteout if your intintion is to peal off the canister. For that matter has anyone ever even tried this? Before putting anything in the canister put it in the forge to get it cherry red then quenching it in water to make it brittle. Then load it up with the hardenable material (No Whiteout). First question is will any cracks developed in the canister be big enough or deep enough to allow oxygen into the canister? Next question: will this technique even work? Will the canister will be brittle enough to break apart after the initial forge weld? Other thought: what would happen if instead of the above technique the canister is filled as usual Without Whiteout, then after doing the initial forge weld the canister is quenched in water to make the can brittle. Will that rapid heat change transfer into the inside steel ruining its integrity?
