Just bought a (stupidly named) CRKT SPEW as I wanted a small fixed blade on a currently very tight budget. Liked the look, size and the wharncliffe seems like it would be good for everyday stuff at home and the office. Also, I figured it would be an easy blade to learn to freehand sharpen on. I just can't get the thing to take an edge. I really want to get this one down before I tackle my "good" knives which are WAY overdue for a resharpening.
I'm new to sharpening and have recently picked up a smiths tri-hone and another cheap 2 sided stone from harbor freight. Also picked up wet/dry paper in 1000 and 1200 grits and a cheap 10x loupe. I've watched a bunch of videos on youtube and read a whole lot of tips and tricks all over the internet.
I've been practicing using the stones and a handful of cheap old knives I have laying around of various blade profiles and styles. I'm able to get a little super cheap (was $2 at a local asian grocer) very thin santoku style knife ungodly sharp. Was able to get a nice edge on most of a big, thick chinese folder; although the slight recurve on it is giving me a bit of a fit in a couple spots. Got an arm shaving edge on a little finnish skinner (might be carbon steel of some sort, no idea really, but it's got a patina to it) that I'd destroyed the edge on as a kid except for the tip which I'd snapped off... Going to try my hand at my CRKT M16-13T (AUS8 maybe?) next which I was able to get an "ok" edge on using the lansky style sharpener. Ultimately, I'd like to be able to get REALLY GOOD edges on my VG-10 Endura4 and my VG-10 chefs and santoku knives.
I want to blame the steel (5cr14 or something) since I know it's crappy, but I can't imagine it's any worse than the other cheapies I've been working with which are probably 420 or 440A. I've used a marker and seem to be able to hold a consistent angle, although I do have some trouble on 1 side of the blade. Need to find a way to get consistent strokes with the blade facing toward me or learn to hold the knife in my other hand to do that opposite edge.
I started on the medium stone on the tri-hone which is allegedly around 600 grit. Pushing edge first, using very little downward pressure on the blade. Worked up a burr, switched sides and used the same amount of strokes to try to keep the profile even. Then alternated strokes each way a few times to knock the burr down. Switched to the fine stone and did the exact same thing. Finished with a few alternating edge trailing strokes on the fine stone. Was then going to use the sandpaper, but it feels higher grit than the fine stone and didn't want to undo what I had done. It was sharper than out of the box, but still won't cleanly slice printer paper or shave arm hairs. The edge doesn't look BAD to me under the loupe but nowhere near as nice as most of the pics I see here.
Edited to add: I believe I'm sharpening at about a 20 degree angle per side. It's just slightly shallower than the angle guide that came with the tri hone which purports to be 23 degrees.
TL
R version. I'm new at sharpening, I THINK my technique is decent, can't get a specific knife sharp and don't want to screw up the edges on my good knives. Help please.
TL
