I use green chromium oxide on a leather strop and cant get a proper mirror edge. Do i need to start with a higher micron compound and work down to the 0.5 micron chromium oxide? You can see reflections in the blade but its a little foggy.
My grits are:
180 (reprofiling)
400
800
1600
I'm not sure. It was only $35 for all four of them but the 1600 grit stone is much much finer than 1500 grit sandpaper
My main blade is S30V but i have also sharpened / stropped many cheap blades with super soft steels. Same result every time.
The finish off of the 1600 grit stone is sharp enough to use but will not shave hair at all.
Thank you. I form a bur on the edge with every stone and my blades can whittle hair but dont have a mirror polish, thats why im so confused.. I think im going to upgrade to the Edge pro apex $245 kit (Apex 4 kit) when i get enough money after i buy a car. IOr do you think i should get the edge pro with chosera stones for $330? It looks like the edge pro stones are much finer on his grit chart.
