Canvas Micarta tip
I recently finished an A.T. Barr Combat model blade blank in canvas micarta (natural/tan) and thought I'd give a report. I initially finished the scales to a polish and the results were pretty cruddy. There were rough spots that turned gray all over the handles and they sucked. So, I used a rough sanding drum on my Dremel and recountoured, then went back over it with the finer sanding drum (probably a 120-220 grit, I would guess). At this point the pores in the material are FULL of dust, so I rinsed it well in the water and also noticed it grips extremely well. When it dries it has a nice sort of sandblasted look to it and it nice and grippy. I left it like this and I think this is the poor-man's solution to bead/sand blasted canvas micarta. I like it a lot. Also, I used red liners between scales and tang and you can hardly see them because the Micarta seems to soak up the epoxy at the joint and turns a dark color. So, don't bother using liners under tan canvas. Anyway, the stuff is nice for field-grade knives, but sucks otherwise (IMHO). I'll post pics of the knife and sheath when they are both completed. The sheath is woodlands-camo Concealex (thought I'd have a little fun!) and should turn out cool.
My Knife & Sheath Pages:
http://www.geocities.com/CollegePark/Lab/1298/frames.html
Palmer College of Chiropractic
Sheath Makers Referral Directory
agocs_s@dd.palmer.edu
Madpoet (Mel Sorg, Jr.) Tribute page:
http://www.geocities.com/CollegePark/Lab/1298/madpoet/main.html
I'm looking forward to seeing the pic!
"Come What May..."
Steve, I'm glad to hear that you have finished that knife. I'm looking forward to seeing it.
When I use canvas micarta, I hand finish with a piece of 220 shop roll. That will smooth out the edges and still leave a good finish for a safe grip.
A.T.
http://www.customknives.com
AKTI #476
Well, I had the knife finished to a gorgeous satin, quai-polished finish and as I was thinning the edge so it could be sharpened, I dragged my dang 60 grit wheel across the dang blade and left a hell of a scar. I spent probably 5 hours finishing that blade, then screwed it up in a blink of an eye! Oh well. I guess I won't have to worry about the Kydex sheath scraping it up now.
try wiping the whole knife down with WD40. cleans off all the dirt and leaves a nice look...if you decide you dont like that effect you can rewipe with acetone.....
http://www.mayoknives.com
Be careful when sanding micarta as it burns easily and will leave a cruddy finnish .Always use sharp sand paper and slow rpm's . I wet sand to 400-Grit and then buff .really nice results . also if you want a nice texture shape to 120-Grit and then sand blast with a coarse grit and then buff with a white compound.
Chiro, I used to do that too, scratch up the blade while fussing with the handle. Masking tape, duct tape electrical tape strapping tape, packaging tape, put a couple wraps of charmin under the tape it's easier than cleaning the gunk off the blade.
By the way, (I feel your pain)
It is better to bear the rebuke of a wise man than to enjoy the flattery of fools.
