Carabou Antler...How Does it Compare?
I was given a dropped tine. It can be a good handle material. The hard exterior surface is about as thich as elk horn. I think its more dense. If you can buy at a reasonable price ans horn pieces that are flat enough you should be fine. Frank
Caribou has little to no surface texture. The tines are normally pretty small but a few are big enough for handles. Main beams are a bit too large usually. As with Elk some are a very pithy. If you cut carefully you can get some scales out of them though. So if the price is very reasonable or you can see the antler and feel the fit in your hand, it could make good handles. The Sammi knives handles and scabbards were made using caribou and normally pieced together. They make some pretty elaborate sets. There are ways around the problems with the bou antlers. Good luck
Ray, you know the difference between caribou and reindeer?
Wait for it
Reindeer fly:D
Same animal, different parts of the world. http://en.wikipedia.org/wiki/Reindeer
Also the female caribou/reindeer have antlers too, normally they are much smaller and more spindly.
Ray, you know the difference between caribou and raindeer?
Wait for it
Raindeer fly
Never knew that!
Raindeer is used in Scandinavia. Good pieces have beautifull white under the bark.
