- Jan 30, 2020
How well do carbide (glass/ceramic) drill bits work on hardened steel?
If they do, recommended drill press speed?
Thanx
Thanx
I just drilled this hole in hardened T3 HSS steel, 3mm ...............800 or it was 900 RPM I don t remember.How well do carbide (glass/ceramic) drill bits work on hardened steel?
Thanx
I never use any oil ,seems to me counterproductive... to lube place where I want friction.If carbide drill bits is sharp job was done fast , very little temperature there.Thanx for the tips.
Natlek...I see you did not use oil to keep everything cool?
What drill bit are you using? I use 65hrc rated carbide bit. 14c28n at 61/62 hrc is no problem. But RWL-34 at 64 is very very toughI just drilled this hole in hardened T3 HSS steel, 3mm ...............800 or it was 900 RPM I don t remember.
And this is 67 HRC M35 steel ....................
You need to sharpen them from time to time ......I have this one from Alpen AustriaWhat drill bit are you using? I use 65hrc rated carbide bit. 14c28n at 61/62 hrc is no problem. But RWL-34 at 64 is very very tough
