- Nov 24, 1999
I'm planning on customizing a spyderco delica 98 with cocobolo dymondwood scales, stainless liners, and maybe flat grinding the blade. If you read my HORSESH*T thread you know how its been going already.
And now I've run into a another hang up. Due to the fact that the knife was made in Seki City Japan, where they use that damned metric system, it has 3mm pins
I don't know where to buy them and would rather not wait another month for peices and parts to be mailed in from all over the world, so I'm hoping I can redrill the pivot hole to either 1/8" or 3/16". And then for the pin in the backspring I'll try and turn down a peice of brass rod using the wonderfully accurate method or chucking it up in my drill press and holding a good square sanding block against it. ( yeah, I'll have to stop and check it alot, but its still cheaper than a lathe)
So the blade is ATS55 and hardened to about RC60 I think. And I need a carbide drill bit.
I've heard that the solid bits are really fragile, and seeing as how the spindle isn't the tightest on my drill press I'm guessing I shouldn't get a solid bit, because it will probably shatter as soon as it touches the tang.Where can I find a carbide tipped bit? I've heard that cement bits are carbide tipped, would that work for one hole? And do you think that I would be better off removing as little material from the hole as possible(drilling to 1/8" ) or should I take more off so that the bit gets a more solid bight into the cut (3/16")?
Thanks for any help. Or if you have a different idea than me I'd like to hear that too.
It'll feel better when it stops hurting.
