- Sep 10, 2010
Hey guys,
I've been using a carbide tipped hammer to straighten my blades for the past 9 months. While I had success on some blades, there were many blades that simply would not respond to even hundreds of hammer taps.
As some of you know, I make lots of machetes and other long thin blades from Z Tuff and 3V with low tempers that are highly warpage prone.
I made a big breakthrough in my technique that I discovered by accident and wanted to share. This all happened when I was being lazy and decided to straighten a blade on my granite kitchen counter top and was able to actually feel the reverberations and pitch of the hammer taps clearly for the first time. There was so much reverberation on my countertop from the little taps that it actually shook the whole house and caused the cups on my counter to start humming in sympathetic resonance. It was pretty dang cool!
Using this discovery, I've been able to straighten even the most severely warped blades in my shop in minutes with only light tapping. (Is this what it feels like to be a real bladesmith?
Guys that forge alot and have been using hammers on an anvil for years probably already know this instinctively but for us stock removal luddites, I want to share so you can stop being frustrated with stubborn warps.
I'll film a video on this for you guys when I'm back in the shop (or kitchen) so you can see it in action and I can better explain it.
THEORY
While we are taught that carbide peening works by stretching the surface of the steel to correct warps, I'm not sure this is the whole story. I now think carbide peening has an additional effect similar to shot peening where its reliving stress in the steel and not just relying on stretching.
You can hit the blade a thousand times and leave a thousands marks and many times the blade wont budge at all. If stretching the surface was the only mechanism of action, the warpage should be corrected after a huge number of taps.
Instead, I've discovered that hitting the blade in the right place, with the correct energy distribution is the real key to fast and effective straightening and its all about FEEL and SOUND.
THE SETUP
1. Use a THICK granite block.
- In the past, I've done my peening on a thin piece of granite or a steel plate backing. using a big ole piece of granite helps you to better feel and hear what is going on with your hammer strikes.
2. FEEL and LISTEN
- Find where the bow in the steel is, use your fingers to secure the blade and start tapping just like you normally would.
- NOW, is the real key, feel and listen with your ears and try to get the hammer taps to resonate.
- Hammer taps that create a dull thudding sound and rebound the energy directly into the hammer are effective.
- Hammer taps that creating a sharp pinging sound and don't reverberate the energy back into the hammer are not working and won't straighten your blade. When the energy is being scattered instead of being sent directly through the blade, its not doing the work it needs to relieve the stress in the steel. Its just getting converted into sound and hurting your ears + leaving a mark on the blade you have to grind out later.
If you are getting sharp pinging sounds and not feeling any resonance in your hammer taps. This is not the right spot on the blade to be hammering, move on and try another area.
Here is a diagram below.
Basically, we want the energy of the hammer tap to go through the blade and bounce DIRECTLY back into the hammer. You can really feel when this is working as your hammer taps will feel really bouncy, almost like you are hitting a trampoline. The steel will feel soft.
THEORY
THE SETUP
2. FEEL and LISTEN
