Titanium is certainly going to be better for being tough. say you were going to shoot a bullet at it, the ti would stand up to the bullet than the CF would.
depending on how its made some carbon fiber would shatter if it was dropped on a hard surface. this really depends on all sorts of factors though. take for instance the lion steel with all the voids, that would have more points of failure than the zt or spyderco stuff.
of course the titanium is very springy an a dense metal. it will likely be no issue ever, though if it were too thin the ti could snap in half (or snap with a few bends, where as a thin piece of cf will only snap if it goes past its breaking point, but will be very flexible under its breaking point. CF is not work hardening like ti is (tho it really does depend on how the thinner cf was made, its highly irregular and varies composite to composite). different methods of making cf will result with different characteristics. as well as the resin to carbon ratio.
a composite used for a boats sail will likely require lots of flex, else it could snap from the forces of the wind and sail. so they use a method called wet layup. another method is prepreg autoclave which a majority of high end carbon fiber production uses. very stiff and dense material, with much more idea ratio of carbon and epoxy. its put into a pressurized and heated oven called an autoclave. while very stiff this method is very strong but has a lower breaking point than wet layup if pushed past the breaking point it will snap. so not idea for excessive flex. a 100 ton press can also be used for either method of layup, this helps compress the layers and remove excess epoxy. There are so many methods of cf production though.
for a pocket knife i dont think any of this matters. the only thing that most people would have happen to a knife like these is, drop it on dense floor, car runs over it.
