It doesn't feel smooth compared to my other knives yet it doesn't feel coarse either nor does it look like its finished much differently The finish looks refined actually which is why i thought it might be a character of the steel. Looking more into it some suggestions is its the grind, flat and thin vs thicker and convexed (spl?). Idk, think ill try the above suggestions eventually and see it it helps. Thanks.if it doesn't feel smooth it's probably finished to around 120 grit. get some wet and dry sandpaper and start polishing, fitz and the like will probably be too fine. you can go as shiny as you feel like.
