Dang, that is made for flipping.American:
Carbon Steel Skillet
Made in the USA. Shop Seasoned Carbon Steel Pans at Lodge Cast Iron, offering quality carbon steel cookware, frying pans, skillets & more.www.lodgecastiron.com
Do you have one? I've been tempted since they came out.Misen has a new carbon steel skillet that is case hardened. It's as close to non-stick teflon as anything I've ever used. So far, I'm very impressed. Very little maintenance, and is very non-stick with just a touch of oil.
Yes, it came in time for Thanksgiving. We have a full house with family, I've encouraged everyone to try it, and everyone is extremely impressed. Food slides around and with a little oil (butter, lard, olive, avocado), and absolutely zero sticking so far. Cooked eggs, pancakes, sauces, etc. They say it's not quite as non-stick as teflon, but I honestly can't tell the difference.Do you have one? I've been tempted since they came out.
I assume you mean performance and not cost. Carbon steel acts just like thinner cast iron. Heats up faster, doesn't retain heat quite as well due to reduced thermal mass.How much of a difference is there between the carbon steel and cast iron, if any?
Which size did you get? Was thinking of adding the 10" to my Christmas list.I assume you mean performance and not cost. Carbon steel acts just like thinner cast iron. Heats up faster, doesn't retain heat quite as well due to reduced thermal mass.
Case hardened carbon steel takes it to a different level. Acidic foods are no problem. Soap and water are likewise no problem. While it might season a little over time, you don't have to worry about preserving the seasoning. It's on a whole different level. The only thing you can't do/shouldn't do is put it in the dishwasher. Very, very non stick right out of the box.
I got the 12 inch size, lol....Which size did you get? Was thinking of adding the 10" to my Christmas list.
I will not comment on the idio... I mean, efficacy of putting skillets in the dishwasher. But, if you do it, be sure to put them next to the wooden-handled carbon steel knives.
Are they case hardened or nitrated or both?Misen has a new carbon steel skillet that is case hardened. It's as close to non-stick teflon as anything I've ever used. So far, I'm very impressed. Very little maintenance, and is very non-stick with just a touch of oil.
Yes. From what I've read, they use a nitrogen rich environment to achieve the case hardening.Are they case hardened or nitrated or both?
