carbon vs stainless
while reading an ad on the bay i noticed one of the questions was it carbon or stainless steel. in the answer the seller stated that carbon tarnishes more than stainless(true), and that the stainless will be harder to sharpen and hold an edge longer than the carbon steel? now this is my question it has always been my understanding that the reverse was true, that carbon steel is harder to get a good edge but once achieved it will hold this longer due to the hardness of the blade being greater than the stainless one. most carbon steel esp. with the greater amount of carbon in them will get harder than the stainless versions due to the fact that carbon is limited in the stainless variety. anyone else find this so or am i just nuts?
My experience has been Carbon = easyier to sharpen Stainless = (depending on version harder to sharpen!!!
Edge holding can be relaitive but from my experience stainless ( again depending on version (IE 420, 440, 134CPM, 14-4 Chro MO ETC) tends to hold an edge longer once you get an edge!!!;)
Schrade carbon and stainless very over:eek: the YEARS IMHO ;) carbon being the closest to staying the same.
Schrade Cut CO and older Schrade Walden will get scary sharp quick and stay that way!!!! BUT back in them days they "didn't" have all the new- fangled diamond sharpeners etc. so I believe that to be an unfair comparison!!!:D I will say from experience that the older blades + new sharpening technology is WAAAAAAAY better!!!:thumbup:;)
You can't really just make easy comparisons like that unfortunately. You have to compare one specific steel to another really. Steel can be hardened to greater or lesser amounts because of the carbon in the steel. This is true of what we knife-heads call "carbon" steel but also it is true of stainless. There is lots of carbon in that too if it's any good.
The addition of elements like nickel or chromium etc to the steel are what turn the "carbon" steel into high-carbon "stainless" steel. There are a million different combinations possible when formulating steel. "Pumaster Steel" found in older Puma knives is one example of a classic good old-school carbon formula as are Schrade's carbon offerings and those of other quality companies.
When it comes to stainless three commonly used grades are 440A, 440B and 440C. 440C is the "hardest" one generally. It has a higher carbon content and so it can be more easily hardened to higher levels as measured on the "Rockwell Scale". The harder a knife the longer the edge should last theoretically. There is a trade off though and an important one at that. As hardness and carbon content increase so does the brittleness of the steel.
In real world use some "toughness" and minute flexibility is also a good thing in a hard working knife. A super-hard blade that snaps in two but remains razor sharp still does you no good. The near-microscopic terminal edge of the blade is also more prone to snapping off if it encounters something hard than would be a softer blade. Either way your knife will dull if you try and cut hard things. Also whatever you sharpen your knives with has to be significantly harder and more abrasive to be able to remove material quickly and easily from extra-hard steels. A diamond-hone is really the only thing that chews up 440C in my experience.
On the other hand 440A (and the stuff we call "carbon steel") has a lower maximum hardness (most steels are never tempered to max levels: makes em too brittle) and so can be easily and quickly re-sharpened and re-sharpened. Keeping your knives re-sharpened after use keeps them always ready. No knife will chop up something and stay sharp forever but you could argue that 440C holds an edge "better".
To really complicate matters for us it seems the reason Schrade always just said their stainless knives were made of "Schrade+" steel was not because it was a secret formula kryptonite-steel no one else could figure out how to make because it's easy to melt down steel and analyse it's composition. They said "Schrade+" to imply that mistaken belief but also so that Schrade could change up their choice of blade steels whenever they liked and the buying public would remain blissfully ignorant. They did do this too so I have read. Schrade+ was 440A, 440C, 420HC, 440B I think at different times. In the late nineties I have read Schrade even admitted to having to "tighten their belts" and drop quality of steel in their production knives.
Really Rockwell hardness number is what speaks to edge retention, strength and brittleness. If you do a great job at tempering 440A you can achieve hardness levels of poorly tempered 440C and achieve a perhaps "better" (and even harder) knife from the "softer" steel. A huge part of the cutler's art is in the tempering of the steel to uniform hardness through the use of heat and cold.
All of this goes together to mean there are no cut-and-dry answers to "Which is better?" or "What is the best?" It depends on too many different variables and the preferences of the user. Here's a good link if you want to learn a bit more...
http://chemistry.about.com/cs/metalsandalloys/a/aa071201a.htm
Super-short answer: Carbon sharpens easier (than 440C or even 440A) and holds a wicked sharp edge but with stainless it's a bit harder to get that razor-sharpness in the first place.
I got one of the last 882UH to be shipped to my local wally world and what ever SS it is takes a wicked edge and keeps it!! I hate to say it but I think I prefer it to my old 80T.
I think too it depends on the angle of the grind to maintain an edge that lasts longer.
(I reply thinking you mean sharpening angle but you may well mean main blade grind. I'm not sure. Please expand...)
My understanding is that Schrade recommended 20 degree bevel each side. The guy who owns a local knife shop tells me this 40 degree edge is also kind of "standard" for german kitchen knives. On the other hand quality japanese kitchen knives are ground at 15 each side for a total of 30 degree edge.
My understanding has always been that the finer the bevel the easier to get max sharp but that it dulls easier because the edge isn't as "chunky". As you get finer you approach a "feather edge" which is not a good thing.
I have always tried to sharpen my knives at about 22.5 degrees each side when doing them on a stone because that was an easy way for me to think of it at first. Tilt to 45 degrees and then half of that again is correct angle.
