Carborundum?
Well, I figured out that my bench stone is a carborundum dual grit. Don't know the grits, but the fine side leaves a nice polish and the stone feels very smooth to the touch.
Anyways, according to wikipidia, carborundum stones are silica carbide. Is this the same carbide that tends to tear the steel away and leave a jagged unfinished edge? If so, it would definately explain the speed of sharpening on it, as well as my inability to get a razor edge on either the course or fine side without a decent amount of time spent on my old worn out arkansas...
Sure is great for reprofiling though!
i have one like that. its like 100 grit on the coarse side. i've switched to an inexpensive king waterstone. Doesn't leave lots of shiny gouge marks on the edge and is much finer.
I was thinking on getting new arkansas stone to finish up on, sounds like a good idea?
I lay a masonary cutting blade from a chop saw on the table and flatten my carborundum stones with it.
Would that work with Norton waterstones?? If so, any special precautions or procedures to observe???:confused:
TIA,
Ben
I just do my cheap carborundum stones that way. The chop saw blade occasionally will leave a groove in the stone. I then have to go to sandpaper on a flat substrate to finish the job. I would not use this method on a stone I valued.
the stones are great for reprofiling. they cost $3 here and are great for farm / gardening tools. I need to finish off on a smooth waterstone though....
