Thanks- good stuff to know. I rarely allow my knives to get truly dull, so stropping sounds like the way.
It's a Bark River Mini Canadian.
How hard is it to convert a v grind to a convex edge?
Hey Liam,
Now mind you, I've never done it, but as a woodworker who's sharpened alot of chisels, this is what I'd do....
Start with 320 wet/dry on, say, a mouse pad. I never thought of the mouse pad thing before learning it here, but it sure sounds good. "Strop" the blade, each side, over and over, rolling gently toward the edge (but NOT touching the edge yet until you get rid of the sharp "V" shoulder), until you get close. I wouldn;t use 320 all the way until the convex grind was complete, instead I'd change to 600 to get it even closer (but not all the way final...just barely off the edge). Then 800 to finish the complete curvature down to the edge. Then 1000 and up as final stropping.
Also, while another poster (longbow50) mentioned that you're sharpening the entire blade, I (personally) would not. I would start the grind just above....just barely above... the top of the original "V" grind and gently roll to the edge. Again I say, longbow50 evidently owns a convex ground knife so he surely knows better than I, I'm just saying I wouldn;t roll the grind from the spine to the edge, even though, through time, that may end up being what eventually happens.
I would guess, on a small to medium sized blade, especially starting out with 320 grit or so, the whole process would probably take an hour or two.... or so.
I'll step aside with this advice if it differs from those who know.
You can also go to Bark River and see their instructions on sharpening a convex blade...shaping a "V" grind into a convex edge shouldn;t be radically different. You're just removing much more metal. http://www.barkriverknives.com/home.html
