I've noticed a benefit to forcing a patina on 1095 (USA Schrade, as used in their Old Timer knives). I forced a patina on the clip blade of an 8OT stockman, but didn't do so on the other two blades (sheepsfoot & spey). The un-patina'd blades have been quick to develop small spots, if I don't stay ahead of them and keep those clean. The patina'd blade hasn't needed nearly as much attention. Also noticed, when doing further forcing on the same blade with vinegar & hot water, the previous patina just turned darker, almost black, while the areas of the blade without patina (the tang, mostly) showed some red rust. Once the patina's in place, the red rust seems to be held at bay, to a greater degree.
When forcing a patina, any red rust that develops during the process can be easily scrubbed away with some baking soda & a little water (mixed to paste consistency). The baking soda also neutralizes the acidity of the vinegar or whatever acids (fruits, etc.) are used to force the patina. Baking soda will also scrub away some of the really dark, black oxide, but leaves a very pleasant grey behind. The grey oxide that clings tenaciously to the steel is what will help to protect it.
Beyond the patina, I don't deliberately oil the blades. They get a little bit of light mineral oil left by WD-40 after I do a major wash (with dish detergent & hot water), after which I flush out residual moisture with WD-40. But, that's all the exposure they normally get, to any oil. Just keep them clean & dry (Windex wipedown), before putting them away at the end of the day.
I'll add that I'm also in a very dry climate (southwestern US), so I'm sure I don't need as much to protect my blades, most of the time. But even then, if they do get wet and/or dirty, I'm usually very quick to clean 'em up again.
David
