Care to proof read?
scdub
Dealer / Materials Provider
Sorry - too many words apparently…
I was hoping to have you fine folks proof-read a paper I wrote to go along with a sharpening class I’m giving on Monday, but it’s too long. I’ll break it up and post again tomorrow.
Cheers,
scdub
Let’s try again - here’s part 1 (note the formatting is funky - I’ll fix that before I print)…
Basic Sharpening Principles and Techniques
(Rev 2024 - by scdub)
Sharpening is essentially sculpture. When sharpening, you are sculpting an edge by r emoving material, just as if you were sculpting a statue out of rock or wood. Understanding this concept is vital to mastering the sharpening process.
Sharpening can be difficult because unlike on a large sculpture, the important part of the shape (the edge) is microscopic. Using a variety of techniques to visualize the edge can help you to create a very precise microscopic shape (a sharp edge).
This paper is intended to be used alongside a hands-on sharpening class. If you don’t have an experienced sharpener available to teach techniques and explain terms I suggest watching a few videos from different sources online before starting off. I also recommend using an inexpensive knife/retractable razor blade for initial practice.
Tools and Techniques
There is no such thing as a “correct” tool or technique to sharpen any blade. Some tools and techniques work better on some blades than others. I have used many different sharpening devices throughout my life with some luck, however I have found “freehand” sharpening to generally be much quicker and more efficient than most other systems.
Diamond stones are now widely available at modest prices. Diamond stones are not required for all knives/blades, but they are very efficient at removing material and are much more effective than other types of abrasives for use on certain steels containing very hard carbides. Coarse diamond stones (~400 grit) are excellent for repairing or reprofiling edges. Because diamond stones remove material so aggressively, I tend to use natural stones and ceramic abrasives for regular edge maintenance.
The general idea behind sharpening is to grind away equal amounts of steel from each side of a blade until you end up with two edge bevels that meet at an apex to form an edge.
Holding the blade at the proper angle while grinding is probably the most important yet difficult to master aspect of sharpening. If you allow the angle to become too steep, you risk making your edge too obtuse. If you sharpen at too shallow an angle you won’t be hitting the apex at all and you are thinning the edge, but not sharpening it. Practice locking your wrist while you sharpen to reduce “wobble”.
I freehand sharpen most knives at approximately 16 degrees per side (for a theoretical “inclusive” edge angle of 32 degrees). By holding this angle, when I wobble a little bit and the final apex edge angle ends up closer to ~20 degrees per side (40 degrees inclusive), the edge will still be at an adequately acute angle to get very sharp and be easy to touch up.
The Sharpening Process
#1) Examine/Test
Determine Edge Damage: Use a single bright light source (the sun or a flashlight works best) to find any reflections on a freshly cleaned edge (isopropyl/rubbing alcohol works well for cleaning).
Reflections indicate a dull portion or chip in the edge. A completely sharp edge will have no detectable reflections at all. Depending on the role of the blade, you may choose to leave in some nicks/chips to minimize sharpening time and/or increase blade longevity.
Another test is to gently run the edge from heal to tip across your thumbnail to feel for nicks/rolls. A sharp, undamaged edge will “dig in” slightly and feel smooth as it glides across your nail.
Determine Sharpness: Cutting paper and carefully shaving arm hair are both excellent ways to determine relative sharpness.
Check for Symmetry: Look closely at the edge bevels and compare one side to the other. If they don’t look the same, this could indicate that the edge isn’t symmetrical, and you may want to grind more material from one side of the blade than the other (see NOTES below).
Find the Edge Angle: This can be determined by measuring or estimating the “slicing angle” at which the blade will start to bite. Using a flat block of wood or a smooth flat surface covered by a piece of paper, lightly glide the knife along the material as if trying to slice a thin piece off, starting at a very low angle (knife doesn’t bite in), and slowly raising the angle in subsequent passes until it just starts to bite. This is your approximate edge angle. If you must raise the spine of the knife to a steep angle before the blade bites in, you have a relatively obtuse edge angle and you may want to thin out the edge/reduce the edge angle on a coarse stone before moving to the sharpening step.
Another popular method for determining the edge angle is to use a permanent marker to color the edge bevels. Then, using a light sharpening motion on a high grit stone, you can determine at what angle the marker residue is removed. The edge angle may not be consistent, so you should perform this test along the entire length of the edge, and on both sides.
#2) Plan
Decide if you want to sharpen at the current edge angle or if you want to “reprofile” the edge bevel. Next, decide what grit abrasive you will start with. If you have a significantly damaged edge or one you want to reprofile, you should plan to start off with a very coarse abrasive/stone (~400 grit or lower). If you have a somewhat sharp knife to start with, you might use a higher grit (smoother) stone or just a strop to tune up the edge.
And here’s part 2…
#3) Apex
If you felt damage or saw reflections during your examination, portions of the edge are not “apexed”, and you should use a coarse stone to grind away material along the entire edge, (I suggest around 16-20 degrees per side for most knives), until the reflections/dull areas disappear and/or you form a “burr” - see below.
I tend to use a back-and-forth motion while sharpening because it’s faster and I’ve developed good muscle memory, but many people prefer to use only “edge-leading” strokes.
Depending on blade shape, it may be necessary to adjust your hand position while sharpening . On a standard blade with a curved “belly” section, you will need to increase the angle between the stone and the end of the handle as you sharpen the belly and tip areas while maintaining the same angle between the stone and the spine of the knife. (This should be seen to be fully understood).
As you grind away material from one side of the edge, a “burr” or “wire edge” will form on the opposite side. You can detect a burr with magnification or by dragging the burr-side of the edge in a stropping/edge-trailing motion across your finger, fingernail or some paper to feel for roughness. A prominent burr will negatively affect edge sharpness and longevity and should be reduced as much as possible.
If I’m starting with a dull or damaged edge, I’ll do a “full sharpening” which is accomplished by sharpening on one side of the edge until a burr can be felt along the entire opposite edge, and then sharpening the other side until the burr can be felt along the entire OTHER side of the edge.
Once a burr has been formed on both sides of the blade I know an edge apex has been created and I only need to remove/reduce the burr to achieve a sharp edge.
To extend the lives of my knives, I only intentionally form a full burr when re-profiling or sharpening a dull or damaged edge. If the knife has simply lost some of its sharpness, light strokes on a fine stone or strop will often bring the edge back to almost as sharp as a full sharpening will.
Once you have an apex, continue to sharpen with your coarse stone briefly, alternating between sides, and reducing pressure as you do so. Alternating sides and lowering pressure will help minimize the burr and should be done with each stone you use before moving to the next higher grit.
An edge that doesn’t have an apex CANNOT be sharpened!
#4) Reduce the burr/refine the apex:
If you create a substantial burr and fail to remove it, it will tend to fold over when you cut any tough material, resulting in a dull knife.
It’s impossible to completely remove the burr at a microscopic level, however reducing it will significantly prolong edge retention.
Using the same angle as above, move on to your next finer grit abrasive and grind away again, but using less pressure. You can use the method from #3 again, creating a new, finer burr along the edge and then switching to the other side to do the same, or you can ignore the burr at this point and just spend a little time on each side of the edge with each finer stone.
In theory, you should sharpen at each grit until, with a microscope, you could no longer see the larger scratches made by the previous grit. In practice, you should just spend a minute or two with each new stone, ending with very light, alternating strokes.
Repeat this process using stones of increasingly fine grits as desired for a more refined, sharper and longer-lasting edge.
#5) Strop:
Stropping will further reduce the burr and refine/polish the edge.
A strop is a flat piece of leather or other similar material that can be used to remove the burr and achieve a higher level of sharpness in blades – particularly razor blades.
The strop should be used with an “edge-trailing” stroke, so you won’t cut into the leather.
Because leather is flexible, it’s easy to unintentionally round-off and dull your edge with your strop. To avoid this, either use very light pressure at the same sharpening angle OR use moderate pressure at a slightly REDUCED angle (for instance, holding ~18 degrees for sharpening, and ~16 degrees for stropping).
I highly recommend using an abrasive compound (diamond suspension is my preference) on strops. Although a plain leather strop can smooth out an edge slightly and remove the burr, it won’t remove much material if at all.
A strop with compound will remove steel, although at a very slow rate.
I use strops both to refresh slightly dull knives and as the final step in sharpening.
Notes
Most variables in knife design are a balance between desirable qualities. A knife with a more acute edge angle, a thinner blade stock, a harder heat treatment, and sharpened to a finer grit should have a sharper edge that will last longer and cut more efficiently. Conversely, a knife with a more obtuse edge angle and thicker, softer steel edges will generally respond to abuse by deforming with less breaking or chipping.
The steel just behind/underneath a very dull or damaged edge is likely to have been weakened through work hardening. These edges may benefit from a fresh start, whereby the edge apex is ground away by gently running it perpendicular (or close to perpendicular) to a stone a few times (and then checked for a solid line of reflection down the edge). This process removes the stressed/weakened steel at the edge and reveals tougher steel underneath.
Many factory knives come with edge angles of significantly greater than 20 degrees per side, which is less than ideal as it makes them more difficult to resharpen and reduces edge retention.
A 20 degree/side edge is generally considered to be tough and still easy to sharpen. High toughness steel knives can chop dry hardwoods without damage at even more acute edge angles.
High precision sharpening is generally slower and requires more mental effort but removes less material and can usually produce a sharper edge at a given angle. High precision sharpening will also generally lead to better looking results. Precision can be enhanced by using “fixed angle” devices or other sharpening systems (although these also require some practice). I sharpen most of my knives with comparatively LOW precision to save time.
The tips of knives are typically a little tricky to sharpen. To avoid rounding/damaging the tip, try to stop the sharpening motion while the tip is still in contact with the stone (rather than allowing the tip to slide OFF the stone).
Because blade geometry (the 3D shape of the blade) often results in more material at the tip for strength, it may be necessary to spend more time grinding at the tip than along the rest of the edge.
Unless a blade has been ground unevenly, the edge bevel on each side of the blade should be the same width if sharpened to the same angle. For instance, if you have a thinner edge bevel on the left side of a knife blade, that generally means that the left side edge should be ground down more (at the same angle as the right side) until it matches the right side.
Occasionally factory edge grinds (or even primary/main grinds) are not properly aligned, and that’s something to look for when purchasing a new knife. Symmetrical grinds from the factory/bladesmith will save you time and effort in the long run.
While you should concentrate on trying to maintain a consistent angle while grinding, the slight human error inherent to freehand sharpening creates a convex edge and automagically thins out the “shoulders” of the edge with each sharpening – both of which are generally considered to be good things for edge stability and cutting performance.
Embrace your wobble!
Thanks in advance for reading!
Please point out any spelling/grammatical errors and let me know if I can improve my clarity anywhere.
I’ve intentionally left lots of information out, however I’m interested to hear from you if you think I should add or subtract anything. Again this is supposed to be an introduction to sharpening and I’ll be using it to teach one of my partners and his family (including a couple of young kids).
He’s already purchased a #400/1000 diamond bench stone and a #1000 Shapton Korumaku on my recommendation.
I’ll be adding to their tools with a little strop I made that doubles as a ceramic rod holder, and a nice flattened piece of Monterey Formation chert that I found awhile back…
Cheers,
Scdub
Looks real good to me, I just had a few comments/suggestions; do you have a DM address or email address?
Well presented, for a relatively new sharpener, like myself…who has been trying to sharpen since the ‘60s with no clue.
I like your mentioning the amount of ‘pressure applied’ at one point. I had to keep reminding myself, bearing down is bad.
I did not have time to read the full text. One thing that came to my mind when I was taking a quick look are your thoughts about different kinds of stones.
I agree that diamond plates are aggressive and are not the best choice for all types of steel.
So natural stones and ceramics are better for keeping knives sharp on a regular basis. Ok. Maybe you could be more precise. Bonded aluminium oxide stones (like all those fancy Japanese waterstones or splash and go stones) are technically ceramics. Although the term ceramic is mostly used for sintered ceramics like Spyderco stones / rods.
Natural stones are able to make very fine, sharp edges while being gentle to the blade. But they work best with low alloy or carbon steels and might struggle with modern steels with a higher Rockwell hardness and amount of carbides.
I know that you want to keep the text short. But as somebody who does not know much about knife sharpening I would want to know that natural stones have their limitations before I buy a set of Arkansas stones and be frustrated because they do not sharpen my 440C, D2 or whatever steel. And blame myself because I think I am doing wrong.
I would reword that something to you should match your abrasives to your carbides. You will have a well worn aluminum oxide hone trying to sharpen anything with very much vanadium carbide in it. I did fine with the old Lansky kit for years until my first D2 steel and suddenly I disliked sharpening. Maybe abrasive to carbide isn't the best analogy but I'm not sure how else to word that. I just remember asking around why I should upgrade to whatever ceramic or plates and being told it's only if you have a "super steel" which made little sense back then.
Sure thing - you can email me at ————. I don’t mind if you post suggestions here though if you like. :)
I did make a couple of changes before printing and I’m on my way home from the class.
Both kids were able to get a retractable razor blade from intentionally dulled on a stone, to raising a burr, reducing it, stropping, and bringing the edge back to cleanly cutting paper. Success!!
I’ll plan to keep updating and polishing this document and leave it here. Feel free to use all or some of it as desired - I don’t even need credit. ;)
Very nicely done and a great resource! Just a few suggestions:
Section #1, third paragraph, "heal" should be "heel".
Section #4, third paragraph, the novice sharpener might want to know "How far do I go, when do I stop, and how many different stones should I use?".
Notes, tenth paragraph, "primary/main grinds" is not defined. Considering the target audience, you might want to explain what you mean.
You end by saying to "Embrace your wobble!", but in Tools and Techniques you say to reduce "wobble", and in the preceding paragraph you again emphasize the need to maintain a consistent angle. This strikes me as something of a mixed message. It might be better to rewrite the penultimate paragraph to say something such as: While you should concentrate on trying to maintain a consistent angle while grinding, a slight amount of "wobble" is unavoidable and if present to a small degree can actually improve your results. The slight human error inherent to freehand sharpening creates a convex edge... I would omit "Embrace your wobble!" entirely.
I'm the wrong person to ask about spelling issues, but that's really good if you ask me! Most of us on here have probably gone down lots of sharpening rabbit holes. Your write up seems like just what someone getting into it should know, without getting too crazy.
In the first sentence you have a space between “r” & “e” in removing
