vjb.knife
- Feb 2, 2002
I have had this knife for a while but just got it out in the last few days to use. On the dock and the surface I have been using a Spyderco Pacific Salt H1 and it has held up surprisingly well for the five or so years of use in a marine environment that I have put it through. I have beat it up and thrashed it and it is still a pretty good cutter. So about a year ago I bought this Caribbean Sheepfoot knife but I did not drag it out until recently and have used it on a couple of tasks with minor rinsing in fresh water to clean it up. There are no signs of corrosion, which is what I expected, because the H1 Salt I have been using has never shown any corrosion and this LC200N is supposed to be better yet. I pulled this nasty nylon rope up from the bottom of the harbor while diving the other day to use as a test cut piece and the Caribbean made short pieces easily. I think I might adjust the angle and put a finer finish on the edge as well, just because I like to be able to see my reflection in the blade edge. But, for now I am happy with it. This picture makes the blade look a bit shorter than it really is at 3.7" / 93mm. It feels good in my hand (which is big) due to the wider handle and the machined grooves give it a solid grip. This is the first knife I think I have had with this type of compression lock, but it seems solid. Life is good.
