Your progress is commendable, Grasshopper (sorry,de debbil made me do dat
) When the swelling goes down in your fingers and thumbs, wrap just a bit of 0000 steel wool along the edge of a stick from an ice cream bar (my source) or a wooden tongue depresser (drugstore, and you get nuttin' to eat). Polish the flat, around the handle ring, and any other large ones in the carving. This is minute finishing, but when the flats take a slick shine, they will show some grain, but mainly they will have an exaggerated contrast to the stippled background, and the parts that are duller. With a little finesse, you can carve/shape the stick end to fit, and use it (light pressure) to burnish the flats you wish to bring up to shine. This is less tedious than trying to do it as you would on a smooth handle. It doesn't work on a larger smooth area, BTW - Causes streaks that need to be wooled down again. On the narrow flats in the carvings, this isn't a problem. Do the burnishing with the grain, and "downhill". All of the cuts in the carving have exposed the grain ends and pores - burnishing in the "uphill" direction raises the ends and opens the pores - "downhill" mats the ends down, and closes the openings. You can see and feel the results of your direction, and make corrections as you go. For graduation, you will be required to bare your forearms and lift a ceremonial bowl made rom a section of barrel cactus. Years later, when people see the pattern of puncture scars, they will either recognize you as a Woodchuck-Lin Master, or turn you in to be drug tested. Either way, your Khuk-fu better than their Khuk-fu. Gotta get a better TV schedule
