Carving through space.
About the exhibition the original table.
[Materials. D2 〔〕 forging. Antlers. 18K gold. Silver nails. Leather.
Characteristics. 1. The author of the first breakthrough in technology works.
2. The middle of a knife "through space carving" high degree of difficulty.
3. Pure handmade creative tool.
Length. 22 cm. Long edge. 10.2 cm. ]
Design Concept
In the design of this knife before.
Mainly due to our normal production of a knife.
Will be cut from a knife-type plate.
But ...
After cutting the remaining plate.
Also can not be completely made into a knife.
So come up with "green re-use" construction manner.
Thus began the design of knife-shaped.
Reason due to the exhibition.
Design is different from the market will come up with less common styles.
The course of several well designed style.
A final decision on this "space through sculpture."
And then begin production.
Learning by doing modifications.
Even the last'18K Circle '
Is also used for many years prior to the purchase of the ring [not used]
"Green re-use" and made.
'Episode'
After the completion of a knife. Would like to use a tool to display a knife.
Therefore, after the design on the production of a little.
Production process.
Originally, the 'legislation' of the shelf with a knife.
Design is not the case.
Because of the construction process.
I put the whole folder in the root Steel Drill article.
Then I started to power. Turned his head to get a tool.
Occurred in the blink of an eye on things.
Steel bars because of "centrifugal force" relationship.
The natural arc of the releases.
At this time two脑子里闪过idea ...
According to the original design or to 'turn corner to change the' do?
The results I chose to 'turn corner to change'
This has naturally made on the curved frame legislation.
It is very beautiful!
Production process here.
http://knifenut.arieslight.com/viewtopic.php?f=10&t=1256
透空雕.
原來展覽簡介表.
[材料.D2〔鍛造〕.鹿角.18K金.銀釘.牛皮.
特色.1.作者突破技術的首支作品.
   2.刀子中間的”透空雕”難度高.
   3.純手工製創意刀架.
全長.22公分.刃長.10.2公分.]
設計理念
在設計這支刀子前.
主要是因為我們正常製作刀子.
都會從鋼板裁切出刀型.
但是...
裁切後剩餘的鋼板.
又不能完全製作成刀子.
所以就想出"環保再利用"的施工方式製作.
於是開始著手設計刀形.
由於要展覽的原故.
設計方面便想出有別於市售較不常見的樣式.
過程中設計了好幾款樣式.
最後決定這款"透空雕".
然後著手開始製作.
邊做邊修改.
連最後那'18K金環'
也是用多年前所購買的戒指[沒使用了]
"環保再利用"而製成的.
'小插曲'
完成刀子後.想說用個刀架來擺設刀子.
所以就稍微設計後開始製作.
製作過程中.
本來那'立'刀子用的架子.
不是這樣設計的.
是因為施工過程中.
我把整根鋼條夾在鑽床上.
然後我先開起電源.轉過頭去拿個工具.
事情就發生在轉眼間.
鋼條因為"離心力"的關係.
甩出自然的弧形了.
這時腦子裡閃過兩種念頭...
要照原設計還是'轉個彎改變'呢?
結果我選擇'轉個彎改變'
就做出這樣自然的弧形立架.
很漂亮吧!
制作過程在這裏.
That is just grogeous and the little display stand is the perfect finishing touch. The would make a terrific desk knife.
Roger
Your creativity and skill are astounding. Every time I look you've done something so entirely different and unique. And you've done them all so exceptionally well.
wow. That is beautiful.
Am I understanding correctly that you used the pieces which you cut out of the steel for the knife, to build the stand?
真是很漂亮,线条流畅、优美,工艺精湛,很有特色的刀。
Momo, we never know what style knife we will see from you next.
However we do know it will always be very well done.
Beautifully balanced design, Momo, with very eye pleasing flowing lines.
Welcome to the world of true art!!
All the best,
David Darom (ddd)
