Newby here with first post. I was gifted a one dot Appaloosa that has a 4 digit number engraved on the handle. It is also referenced on the box as Disp. No. I’m sure it’s a simple answer but I cannot find it googling. Thanks in advance for your help!
I'm not sure what your actual question is.
A Case 6220 is a Peanut pattern. I'm guessing that "A" stands for "Apaloosa", but I'll defer to those who can do more than guess
Here is how to post pictures as a registered member.
As a registered user, you can post pictures using a picture hosting site. There are several free ones. If you use imgur,
create a free account
Click <NEW POST>
Follow the directions to upload.
Once a picture has been uploated, go to the top right and mouse over the bubble with the first letter of your user name. That gives you a drop down.
Select "Posts"
That will show all your images. Click the image you want to post, then to the right at the top, copy "GRAB A LINK" address.
Then go to your post and click the "insert Image" tool on the tool bar. (It is located between the LINK...
Sorry if I was not clear with my question. I am asking what the number referred to as a “Disp.No.”is. On the handle I have the number 9220 and the same number appears on the original box end under “Disp.No.” Totally separate from the A6220 stamped on the tang.
