Case Blue Sycamore handles?
Case has a new scale material that I am really liking, blue sycamore. I don't know much about sycamore, I'm guessing its dyed blue, but I may be wrong? Anyway, thoughts and opinions of sycamore as a knife handle would be appreciated! Eyeing a full size Case Trapper/blue sycamore.
I'm torn. I always thought sycamore was a pretty soft wood.
Janka hardness for sycamore is 770. Sugar (Rock) maple is 1450, Black Walnut is 1010, white oak is 1350, and other maple species range from 700-950.
Compare this to some pines:
Eastern White 380
Ponderosa 460
Longleaf 870
Shortleaf 690
Loblolly 690
And the woods that have the longest history for use as knife handles:
Gabon Ebony 3080
Macassar Ebony (used by Buck for the 110/112 through least the mid 80s) 3220
African Blackwood (historically frequently sold as ebony) 3670
Cocobolo 2960
Desert Ironwood 3260
My parents actually have several Sycamore trees on their property. I can attest it is a softer wood. But as others have said it is stabilized so it is harder than it is normally.
Here's a black sycamore Case did a run of a little while back.
A Case/Bose on a Sycamore leaf.
Eastern White 380
Ponderosa 460
Longleaf 870
Shortleaf 690
Loblolly 690
Gabon Ebony 3080
Cocobolo 2960
Amazing detailed info!
Hardness questions aside, the sycamore on these Case knives is striking material. If it is indeed stabilized, that will go a long way toward mitigating the natural softness of the wood.
For those who don't know what Janka hardness means, it is the number of pounds required to press a 7/16" steel ball to half of its diameter into the wood. It is a popular measurement for wood flooring because it is a direct measurement of the anticipated damage by things dropping onto the floor or by women wearing stiletto spike shoes. When I was an undergrad I had a job cleaning the floors in the admin building, and the areas frequented by stiletto wearing employees were a mass of shallow divots in the floor. 100 pounds on a stiletto spike converts to about 1500 PSI, with the impact of taking steps making it even more.
Once you stabilize wood, I'm not sure the Janka hardness is totally relevant anymore. I mean, canvas can't even be rated on the Janka scale, but canvas Micarta is just stabilized canvas, and Micarta makes for a tougher knife scale than any unstabilized wood.
This is a bit off topic, but here goes...
There was a sycamore tree on my parents' property when I was growing up. (In fact, it's still there.) For some reason I could never remember the name "sycamore," so I developed a memory aid: I called it the "Indian tree." Here's how it worked: Indian > Mohawk > Mohican > Last of the Mohicans > James Fenimore Cooper > "Fenimore" sounds like... sycamore! The human mind is an incredible thing! 😁
Probably true. Janka hardness is used for untreated wood. Stabilizing can change everything. Does anyone know if these Case sycamore scales are stabilized?
Eastern White 380
Ponderosa 460
Longleaf 870
Shortleaf 690
Loblolly 690
Gabon Ebony 3080
Cocobolo 2960
The Janka hardness method requires that the wood being tested have a moisture content of 12%.
But if you look at the commercial lumber web sites, the available sycamore wood is kiln dried. In North America, "kiln-dried" means a moisture content of 6-8%, and it's a North American wood. Lower moisture content means harder wood. That means the sycamore wood being used is harder than what the Janka hardness would indicate. Once dyed and stabilized, it will not absorb more moisture. So the Janka hardness readings for sycamore wood may be misleading. (My father was in the lumber business and dealt in kiln dried exotic hard woods. )
I came on here to bash on the sycamore scales, because when I got my Case Seahorse, the scales were so dry I was afraid I was going to get splinters on the scales. I changed my mind after I waxed the handles with several layers of wax. The scales are silky smooth now. For those who own the knife and find the scales feel dry and brittle, give it a bit of wax and the color really shines.
