Case CV Chestnut Trio: 2 Strikeouts and a Home Run
Planterz
Іди на хуй Путін!
Having received my federal income tax refund last week, naturally it was time to splurge on some new knives. 3 of them were Case Chesnut CV bone that I've been itching to get my hands on. One is great, but unfortunately the other two are being returned to the dealer.
The knife that's great is the Sway Back Jack. This shouldn't be a surprise to anyone here, as even the hardcore customs collectors here have been raving about the SBJ. I was a bit trepidatious about this knife, being barely over 3" in length. It's not that it's not "enough knife" to be useful, but rather that the handle length would give me not enough knife to grip; my Case 6344 stockman at 3 1/4" is barely long enough, and the SBJ is even shorter. But I bit the bullet and am happy to report that it's not too small. Probably due to the fatter handles and sway back curve. The bone on my particular example has black highlights (or lowlights, I guess) on the chestnut.
Everything about the SBJ oozes style and craftsmanship. It's obviously a sexy knife, with the swedged wharncliffe and curved handles. The fact that springs sit flush when the blades are at half-stop definitely adds to the appeal. But what I think really sets this knife apart is the way the springs also act as the butt of the knife, especially how the pen blade spring is one large piece that fills up the unused length of the handle instead of leaving a gap. As an aesthetic, open gaps on a knife irk me (why not just make the blades longer?), and the SBJ corrects that peeve with class.
If only they made a 3.5" version...
The second chestnut I got was the medium stockman 63032 pattern. I like the 3 5/8" size. It's a happy medium between the just-a-bit-too-small 3 1/4" - 3 3/8" stockmans that are so common, and the 4" size stockmans. The blade lengths though aren't really all that much longer than what you'll see in 3 3/8" stockmans from other brands, such as the Buck 303; less extra length than you'd expect for the overall size difference in the knives. That's not really an issue though. The issue with this particular knife is that the sheepsfoot and pen blades are too close to each other. So much that the pen blade is very difficult to open, and practically impossible to open without gouging the heck out of the sheepsfoot blade. I don't know if this is a design flaw common with this pattern, or my example just had the blades too close together (but it doesn't look like there's much room to not have them so close). Even if the blades didn't rub, the pen blade's opening arc runs the blade right into the nail nick of the sheepsfoot, which is what makes it practically impossible to open without deliberately grinding the blades against each other.
So the stockman, unfortunately, is going back for a refund. Damn shame, because otherwise the knife is nearly perfect. The clip blade had the slightest bit of wobble, but nothing to get in a twist over. No gaps between liners/springs, and the bone was a beautiful uniform color, with zero gap and perfectly smooth transition to the bolsters.
The third chestnut I got turned out not to be a chestnut at all. It's a congress, pattern 64052, model CA6992. The website I purchased it from describes it as chestnut bone (the url even has the page for this knife as /casemediumcongresschestnutbonecv.aspx). But it's not chestnut. The box it came in had matching a matching #, but simply says "Red". I'm not sure this knife even exists in chesnut, or at least is not currently available. Googling CA6992 returns results as being "Dark Red", and shows the same stock picture as the website I ordered mine from. Only one other website has it described as "Chestnut", but it also says "dark red" in the description.
If the knife I received had been dark red, or had at least matched the color shown in the stock photos, I would have been OK with that. But unfortunately, as you can see in the picture below, it's not. It's more a pinkish-salmon, a color that frankly I don't find attractive at all.
Even if the color was what I wanted, I probably wouldn't be happy with the knife anyway. Based on what I was told and info I pieced together from the 'net, I was expecting the knife to use 2 backsprings like they did on the 64052 back in the old days. Instead this one uses 4 backsprings, like I guess every model with this pattern apparently does these days. 4 backsprings would have been OK if only it was just a hair thicker. Compared to my Steel Warrior congress (which looks like a clone of this Case pattern), the SW is just a bit thicker. Very marginally so; there's no way anybody could think the Case was pocketable but the SW wasn't - the difference isn't noticeable unless you're looking at them side-by-side. 1/16" or less. However, this tiny difference makes the springs, and thus the blades thinner. On the SW the blades aren't too thin, and you have to try pretty hard to get them to flex. On the Case though the blades are quite thin, and the 2 master blades have a ton of flex. The hollow grinds might have a part in this (the SW blades are flat-ground), but the thinness doesn't help either.
So unfortunately, the congress is going back for a refund too.
At least the Sway Back Jack is a nice knife. So nice that I'm left with a dilemma; what do I do with the refunded money. The next knife on my list to get was going to be a Queen Dan Burke small barlow, but the SBJ is so nice that I'm considering getting a second one, either another Chestnut CV or possibly one in stainless and stag.
Forgot the pictures...
attachment.php
Here's what I was expecting with the congress:
attachment.php
(Stock Case photo)
As some have said around here before, it often looks like Case needs to invest in some new ink cartridges -- a lot of recent (last few years) normal production chestnut bone is kinda weak (the Bose Collabs' peachseed chestnut tends to be very good - as do the chestnut SBJs) - though your stockman is pretty decent.
I think I've only ever seen a couple examples of "Dark Red" bone that I thought deserved the name -- and a few others that were more "Bright Red" -- the rest seem to be similar to your congress, plus or minus a couple of shades of red.
I find the issue that you had with the 63032 stockman to be fairly common in smaller stockman knives. I guess that's part of the reason I've gravitated away from stockman knives to jacks. A stockman layout is great when it is done properly, but I've seen a lot of them that have blade rub between the sheepsfoot and the spey (or pen).
Ed
Its very common, the blade rub in stockman pattern. I got what, 5 or 6 stockman's and only 1 is one that is not doing blade rub. I got Case, Buck, Parker-Frost, camillus made, Hen&Rooster and few Schrades. I get it sometimes other patterns, even my GEC 4-blade congress had bit, but that was due thin blades and I pressed too hard and blade bent to rub another.
Its an art to do multiblade knife that has no blade rub, like my GEC congress was. Now few blades have rub marks and I've learned to open that knife so that there's no rub marks. Stockman pattern is very hard to do properly, especially smaller sizes, while keeping tolerances so that blades won't rub. I got Case medium humpback stocman. No blade rub between hoof and spey. Spey is so thin, though that its easily pressed against sheepshoof when opened, henche the blade rub on that too.
So far I haven't heard anyone say anything bad from Case Chestnut SBJ. I got one and its honestly, best Case knife I've seen, Rivalling best of GEC's I have for the half of the price I've paid best of my GEC's ^^
Go for the Queen/DB small barlow if you can find one. It's every bit as wonderful as the SBJ in a different way. If I had to sell one or the other, the Case would be gone.
That's kinda what I was thinking. I really want the SBJ in stag, but those will be easy to find for a while. But there's only a couple places left that have the Queen Burke barlow, so I should probably snatch one up while I can.
EDIT: Just ordered the barlow.:)
My redbone medium stockman looks more pink then red. The picture had me expecting more of a brown with red tint.
That congress you got is not close to a dark red and any product description calling it chestnut should be fixed by the vendor. The ends of the scales look like they just stuck a toe in the dye and didn't leave it there very long.
The swayback looks great though, that's a nice pickup.
I just picked up the chestnut stockman as well.
The bone color is great, just like in the pics. What isn't great is the blade rub between all 3 knives.
I decided to ignore it, despite the gouge marks on all 3 blades. I figure that when the patina sets in it should be less noticeable.
Hopefully I won't regret the decision. I would have gotten the SBJ in chestnut, but already have a wharncliff trapper if I felt the urge to carry a wharnie...
I may just grab the SBJ regardless :-P
I handled two SWJs in chestnet that where no go. One the hafting around the butt was deeper on one side than the other, and it came to a point on the other side. The other looked like the bone got hung up in the jigging machine and gouged a straight line across the handle. Myself, I bought a dark red slim line trapper in CV just yesterday, but the one on display looked like they should have called it peppermint candy bone! It had a very white base, with red just soaked in shallow. I asked if that was the only one they had and was showed another that is deep dark red! That's the one I bought!
The short of it? If you can make it to a dealer, looke'm over before you buy a CASE. They make fine knives, but some are better quality than others of the same pattern.
I own the SBJ in chestnut and CV as well as a CV/chestnut peanut and both are about as perfect as I could want. Definitely better than the average Case in my limited experience.
I have the same two knives and echo Eric's comments exactly.
Chestnut bone is my favorite Case handle color/material and I have been tempted to get an 032 Stockman CV in it but, like Planterz, I don't like the blade rub and previous Case Stockman knives I've had all had blade rub. :mad: (My solution: only buy two blade Case knives ..... Peanut, SBJ, Texas Jack, Trapper).
I have three SB jacks. Two of my chestnut bone CV version are perfect. The SS Gent had some issues including the blade rubbing on the liner.
I recently picked up a 52 pattern Case congress and was also surprised to find that it had four small springs. It's from 1996 so the switch from two springs to four springs must have been made some time ago. The walk and talk is OK but a little on the soft side. None of the four blades have any rub at all though.
Blade rub is something that I've almost come to expect on production stockman but the three back spring knives like the Case Humpback Stockman and Buck 301 seem to be less prone to problems. I have a few stockman on the way from other manufacturers and I'm anxious to see if they'll have blade rub. One is from GEC and I read a post claiming that GEC knives have no rub at all. I hope it's true.
The Dark Red has been discribed as a 'hose lipstick'
I have a small 6344 stockman, and the color is almost pink!
On my chestnut 63032 stockman the pen also catches on the sheepsfoot
I hate to say it, but thats what I expect from a $35 Case.
What do I want perfection of a $10 Rough Rider??
Seems I've been the lucky one.
My Chestnut cv Stockman works fine with no problems and good snap. Been very pleased with it as I like the Pen blade in pref to Spey.
CASE are not as costly as GEC for instance and I suppose this will show in build/finish. Certainly a GEC Calf Roper in Garnet Bone (there's a decent dark red for you) will doubtless be of superior quality, but it will be around 100USD about twice the cost of a CASE. Both knives are about the same size though. GEC's Amber Bone is not too far off Chestnut Bone either!
I started using my red bone CV humpback whittler as my take to work knife quite a bit and it like the blades seem to be getting darker with age and use. I hope it keeps doing so! The shield side is just about right but the off side could use some darkening. Here's what it looked like new....
I agree mostly. In my limited experience of traditional knives, issues like blade rub on multi-blade knives are also common on expensive knives. ...And manufacturing errors occur even on top of the line production knives.
Earlier this week, I received and immediately returned a Case/Bose collaboration knife because of a loose blade. That definitely isn't representative of the quality of the other Case/Bose knives that I own. The muskrat has the best fit and finish of any knife that I have ever owned. And the blades on my Norfolk knife fit so closely together that it seems like magic that they open so smoothly and without any rub.
GEC is putting out some nice knives but I just received two today and both have some issues with the blades. The Calf Roper had blade rub straight out of the tube. The spey blade is so close to the sheepfoot that it is impossible to open the spey blade without it rubbing against the thickest part of the sheepfoot blade... well... unless you open the sheepfoot blade first and then the spey blade. This isn't due to lateral force on blade. The spey blade is just tucked way under the sheepfoot. And the sheepfoot doesn't seem to be crinked (is that the right word?) at all. There's plenty of room between the sheepfoot and the clip blade that the sheepfoot could have been crinked away from the spey blade. I also received a Canal Street Cutlery stockman and the blades are more evenly spaced with the sheepfoot crinked waaaayyyy over toward the clip blade so that the sheepfoot and spey don't rub. I'd like to see GEC do the same.
There was also a problem with the GEC dogleg that I just received. The tip of the pen blade is about 1mm above the liner in the closed position. It is high enough that it cut my hand when I was handling the closed knife. I think the kick probably needs to be taken down a bit to solve the problem.
Photo of the pen blade in the closed position.
After carrying and playing with th stockman for a few days, the blade rub has reduced quite a bit.
Maybe I'm just subconsciously opening them to avoid it (or the gouging has made space), but it's noticable.
Now my only gripe is a bit of a weak snap on the clip point blade, and the lack of patina. How long do I have to wait for one of those anyways :-P
