Case drop point Russlock
I've got a couple of them - not that yellow EZopen model but some earlier ones with jigged bone handles. I prefer the clip-point version.
Here's one of my drop-points (not the best pic):
This is the one I like to carry:
I've handled several russlocks trying to find a perfect one and they all had the same f&f issues. All 4 I ordered had unacceptably large gaps between the backspring and liner(lock) and also substantial gaps between the bone&bolster on the right hand pivot. These gaps are big enough to fit your fingernail or several sheets of paper through. The blades grind thickens considerably on all 4 towards the tip, making it very hard to get the tip sharp while keeping it consistent eith the rest of the edge. After a bit of use, the blade one the one russlock I did keep developed side to side play. I know these gaps dont affect thr performance of the tool, but I expect much more from Case. If I had spent 10 dollars on a roughrider produced russlock or something these would be acceptable imperfections. If you do plan on buying one, do it where you can handle it before purchasing.
That amber bone I showed above is a flawless example - silky smooth action, easy to open, no play, solid lock-up, good fit and finish. I bought it directly from a respected collector of that particular pattern through another forum so I knew I was getting a good one.
The blue bone version was from Collectorknives.net, purchased NIB and really nothing wrong with it other than the color not being one of my favorites. At the time I bought it, Case hadn't made the drop-point version and I wanted one as a potential carry knife, so I kind of went with what was left in stock.
I just prefer the lower profile of the clip blade, especially when closed, over the drop point. The actual profile of the cutting edge itself is very similar, but I like a point for occasional piercing cuts. If you can get past the admittedly odd appearance, it makes a pretty decent one-hand-opening locking slipjoint.
Once you get used to the motion required to open it, you can flick them open pretty quickly one-handed, and even close them one-handed without much extra effort.
