- May 6, 2011
Hello I would like you to tell me how to case harden some steel plates. I dont know if there is anyone better to ask then knife makers.
These are going in my plate carrying vest and will be worn over my soft body armor.
The steel plates are just regular steel stock sheets. I think they are a one size down from 1/8 or they are 1/8 inch. They have been cut to 5x7 and slightly rolled for use as my side plates. I also have 2 bigger ones for front and back, also slightly rolled. I am going to use a propane weed burner to heat the steel. :nevreness:
This is what I think I am suppose to do:
Heat the metal till it "greys" and then put it in oil so the carbon bonds to the steel. Use black motor oil b/c it has higher amounts of carbon in it. - I was told not to let the medal turn orange b/c this will change and weaken the structure too much and ruin the metal.
Which type of oil should I use?
How many times do I heat and dip it?
How long to submerge it for?
How hot to heat it and how to recognize temperature?
Some guidance from you guys would be great. The more direction I can get the better,:stupid: please explain it to me like I am a child...
Thank you
Thank you
